Never understood this.
people are the same way. if we have problems doctors diagnose our symptoms and make educated guesses as to what it actually is thats causing that. there are a bunch of different things that can cause the same problems so the diagnostic tool is going to give you all the possibilities of what might be causing it.
If you are married, you should have no trouble identifying things that can be indirect such as fault codes. Its just a process of elimination and random equations in your mind you must figure out before you get a pillow thrown at you and are told to sleep on the couch.
lol true that
ORIGINAL: onepoint8tee
If you ignore your wife, that only leads to a chain reaction of problems down the road, just like with an Audi. Youve got to maintain that beotch!!!!
The only reason I brought this up, is the dealer's parts man
said this L shaped formed vacuum hose breaks often, and
should be the first place to look when you have a lean
indication.
indication.
