new cel
Old Nov 20, 2005 | 08:00 PM
ecksman's Avatar
Default new cel
i just had the codes ran and po116 came up. i lookefd it up and it sais engine coolant temperture circuit, range or performance problem. does anyone know whati have to do to fix this? oh yeah i have 97 12v
Old Nov 20, 2005 | 08:45 PM
Jestnomen's Avatar
6th Gear
Default RE: new cel
Yep, just go buy a new coolant sensor and replace yours.
Old Nov 20, 2005 | 10:44 PM
david9999's Avatar
Default RE: new cel
Harness connector on Engine Coolant Temperature (ECT) sensor -G62- loose or corroded due to dampness in the harness connector
- Check harness connector for tight fit and contact corrosion, if necessary reconnect and/or clean, installation location page 28-7
Wiring conection to Engine Coolant Temperature (ECT) sensor -G62- faulty, or sensor -G62- faulty
- Engine Coolant Temperature (ECT) sensor -G62-, checking page 28-25
Engine Control Module (ECM) -J192- faulty
- Replace and code engine control module page 01-265 erase DTC memory and test drive check DTC memory
