Headlight Washer Jet
Old Nov 16, 2005 | 04:44 PM
pdlh's Avatar
Default Headlight Washer Jet
Just had my car serviced (A4 2002) and I have been told the front left headlight washer is leaking. Apparently they break easily? anyone had any experience of this. The garage said the part was about £20 but it needed about two hours of labour to do the job. They have to remove the front bumper? Anyone had a similar experience? can shed any light on what may need doing or the parts required? I do not really want to spend £150 getting it fixed.
( I wondered where all the pisser water had been going ? ? ? )
Thanks
Paul . . .
Old Nov 16, 2005 | 05:30 PM
sandman's Avatar
Default RE: Headlight Washer Jet
im not sure if this a common problem but it only takes like 5-10 minutes to remove the bumper. that is on the b5 though..
dankhound's Avatar
You need a new headlamp washer cylinder. Youll also need a clamp for the line. You may want to take a look at it from the bottom. Depending on the side and motor in your vehicle you may be able to get to it without removing the bumper. Otherwise youll have to remove the bumper which isnt too dificult if your fairly mechanically inclined.
Old Nov 20, 2005 | 10:57 PM
david9999's Avatar
They break ALL the time
Old Nov 20, 2005 | 11:13 PM
BzeA4's Avatar
Yea they break. Just leave it. Thats wayyy too much to have it fixed.
mcanedo92588
Jul 1, 2013 11:27 PM
twilliams83
Apr 2, 2011 07:47 AM
Quaberto
Sep 20, 2006 10:08 PM
cdnskier
Jan 7, 2006 11:12 PM
A4orced
Aug 22, 2005 07:08 PM
