New to the forums need help please.
Old Aug 17, 2006 | 01:54 PM
onepoint8tee's Avatar
Default RE: New to the forums need help please.
ORIGINAL: Audi8U
for the audi i would like to do first Intercooler,BOV,k&n pod,Injectors,Value Springs, and a better induction system and what hp should i be lookin at then?
A diverter valve and BOV are two very different things when it comes to an Audi. Please search on "BOV"- dont use one. injectors wont do anything other than make you run rich unless you have a bigger turbo and supporting software. Either chip it and maybe do an exhaust and intake, or get a big turbo and supporting mods (software, injectors, fuel pressure regulator, fmic, exhaust, spark plugs, etc.) All these things have been covered MANY times, it would be easier and faster for you to get your info by searching for it.
Old Aug 17, 2006 | 04:33 PM
captcaos2002's Avatar
You do not want a BOV, you can get a DV for the same purpose, and as mentioned before they run between 30-150 US dollars. The DV is a lot better for your Audi.
Old Aug 17, 2006 | 04:57 PM
socal_A4's Avatar
you also dont want to get a K&N trust me its bad there is another thread on here called green air filter vs. K&N air filter read it and it will tell you why.... the search button is your bestfriend
Old Aug 17, 2006 | 05:10 PM
But what about that old dude in K&N advertisements that drove 1 MILLION MILES on his K&N filter?!?! Lying scumbags!!! I guess my engine is fucked!!!
Old Aug 17, 2006 | 05:13 PM
smokeU's Avatar
^^^ hahaha! only if the K&N is over oiled I've had it as many others with no problems. if there is a problem you clean it. Our MAF's are tempermental by nature.
Old Aug 17, 2006 | 08:09 PM
Adam@mvp's Avatar
i hope you are not wanting to put an intercooler on with the stock turbo cause that would just be a waste and probably lose power
if you want to make good power go with FMIC, a Garret 2871R turbo is like a good common size "BT" Big turbo
fuel system
chip or what ever map you want to support that turbo
K&N filter or someother induction system...
Intake Full exhaust down pipe mid pipe ect...
and internals if you want like
je pistons
ferrea springs and valves
Carrillo rods
and what ever else you would want to make a good quality motor
and not be cheap about it.
cause being cheap gets you no where but with a broken motor.
DragonAether
Nov 27, 2009 06:12 PM
evan671
Sep 2, 2009 03:05 PM
FezA4
Feb 5, 2008 04:52 PM
rezurrected
Sep 21, 2006 10:22 PM
