New owner -- cranking issue?
Old Apr 6, 2007 | 04:46 AM
The Orange Remix's Avatar
Default New owner -- cranking issue?
Hello,
I am not quite sure if there is a thread like this already, but I haven't been able to find one.
I own a 2003 A4 1.8T and it seems like every so often, when I start the engine, I have to crank for 4-5 seconds before the engine turns over whereas normally, it takes about 1-2 seconds. This seems to happen whenever the engine is warm (i.e., shutting off the engine for < 1 hour). When I start it up in the morning, it usually turns over just fine. I wanted to know if anybody else had this problem before and if so, how they fixed it?
Thanks.
Old Apr 6, 2007 | 04:57 AM
onepoint8tee's Avatar
Default RE: New owner -- cranking issue?
Possibly a bad coolant temp sensor
Old Apr 6, 2007 | 09:57 AM
kyliefrancois's Avatar
i have an 03 with a 1.8T in it and on average my drives are over an hour long and when I shut off, i let it run for about 2 min, then when i get back in to start up, it helps to turn the key to on for about 30 seconds and then crank it over.
i ahd the same problems, like it just seems like it takes too long to finally engage but try this and it might help a little, it does in mine.
Old Apr 6, 2007 | 10:25 AM
david9999's Avatar
Get the car scanned for codes and post them back here.
Old Apr 6, 2007 | 12:41 PM
The Bishop's Avatar
Mine did the same thing. It was a bad coolant temp sensor.
Old Apr 6, 2007 | 04:08 PM
I wonder if I should take it in to the dealer to have it looked at. As of now, it doesn't seem like it's that big an issue. Or should I just wait until the major tune-up before 50K miles to have them handle it then?
Old Apr 6, 2007 | 08:35 PM
david9999's Avatar
If your car is under warranty take it to the dealer. If you are out of warranty, and unless you want to pay twice what it is worth, take it to an indedendent shop.
BillyChile
May 20, 2014 02:12 PM
benni302
Sep 15, 2013 04:10 PM
StevenGrande
B7 Models
Feb 24, 2013 09:39 PM
TM (Ghost)
Aug 31, 2009 06:12 PM
GDigger
Sep 25, 2007 11:16 AM
