New Tires
Old Sep 30, 2007 | 06:28 PM
Crowley's Avatar
Default New Tires
I was told that because my two front tires are worn, that i need to change all four tires. the person said that it has something to do with the quattro and that it says in the manual to change all four tires. is this true or is he just trying to get me to buy two more tires?
Old Sep 30, 2007 | 06:34 PM
Audi_Skydiver's Avatar
Default RE: New Tires
No it's true. If you don't have tread that is within a certain range of each other it will cause all your tires to wear fast and it might mess up the quattro since it will be turning at different speeds (the wheels).
Someone correct me if I am wrong but I have heard this many times before.
Old Sep 30, 2007 | 06:43 PM
wood_e's Avatar
^ pretty negligible if you ask me, but yes, you should replace all 4.
Why not buy my Wheels and tires??? It will be less than a new set!
Old Sep 30, 2007 | 07:09 PM
Crowley's Avatar
how much?
Old Sep 30, 2007 | 08:00 PM
wood_e's Avatar
$525 shipped for the wheels and tires - info: https://www.audiforums.com/m_648498/tm.htm
Old Sep 30, 2007 | 09:36 PM
Crowley's Avatar
the tires in the back are fairly new and have a good amount of tread on them, does this matter?
Old Sep 30, 2007 | 09:40 PM
kolan67's Avatar
damn my tread is so messed up.... my right side wheels are brand new... and my driver side wheels are almost slicks
Old Sep 30, 2007 | 09:48 PM
wood_e's Avatar
you could probably replace only the two and be ok
Old Sep 30, 2007 | 10:40 PM
Trey25's Avatar
Its always recommend to replace all four at the same time. But if you just need two put the new ones on the front, for obvious reasons. I work at sears auto, if a car has awd/4wd we can't sell just two tires. So yes he was trying to get you to buy two more tires but its really the right thing to do on these cars.
Oh btw read this https://www.audiforums.com/m_474623/tm.htm
ORIGINAL: kolan67
Sounds like you got alignment issues.
bigatstyle
Nov 9, 2012 08:29 AM
dlyskawa
Dec 17, 2007 12:32 PM
pindonesia
Nov 16, 2005 11:43 PM
jmerrell
Aug 25, 2005 04:01 AM
miamitrails
Aug 17, 2005 03:08 PM
