new turbo kit help
Old Jan 17, 2006 | 08:22 PM
SoopaSexyS4's Avatar
Default RE: new turbo kit help
is neuspeed more like apr then? i've read in this forum that giac "kicks you harder in the pants", but apr is smoother.
Old Jan 17, 2006 | 08:30 PM
tip5's Avatar
ORIGINAL: InsaneHatter
all I have ever heard about neuspeed products is that they are the super weak sause , extra mild.
Go with a part togther kit..
look on audizine.com, audiworld.com, vwvortex.com
you may find something...
There are all crank numbers keep in mind.. you will pulling 22% less to the wheels if you are AWD, and maybe 11/12% less for FrontTrak
Why a part together kit? to save 200 or 300? 300 more from awe thats proven is nothing compared to having problems later on with some **** parts you find on ebay or another forum.
Old Jan 17, 2006 | 08:42 PM
InsaneHatter's Avatar
I never said buy **** parts....
"Why buy new, when slightly used will do, esp. when the deals are this good" 2nd Wind Dude.
I could understand not parting together the stage 3+ apr kit .. that s a little bit more extensive..
but a k04 kit?
turbo,plugs,install kit,fpr,software.... not very hard to install either... no new manifold... no new exhaust ... no dump pipe... stock location
if you are going to buy a kit for 1800 .. just do a eliminator from ATP... sure their software sucks.. but you can go w/ unitronic software I belive and get good results....
a k04 isnt rocket science... its barely a box full of parts....
if you can save 300$ why not? Alot of what you are paying for with the AWE kit is convienince.. like when you buy pop/chips at the gas station they cost more.....
Old Jan 17, 2006 | 08:51 PM
clconversion's Avatar
exactly $1800 is a lot of cash when you are going to want more power in a month buy used then sell used when you want to go bigger like I said www.audizine.com or www.audiworld.com you can piece togeather a K04 kit for dirt cheap
Old Jan 17, 2006 | 08:53 PM
haha yes Neuspeed's K04 sucks ***
[quote]ORIGINAL: InsaneHatter
Old Jan 17, 2006 | 09:21 PM
drkenan's Avatar
Hey clconversion...what kind of numbers does GIAC claim for the J31 and how much different is it than the pc-16? I can't find any info on the GIAC site. Thanks.
Old Jan 17, 2006 | 09:24 PM
i think with the j31 file it is 250hp the j31 is only for the 2000's as the pc-16 is for the 99 and down and is pretty close in #'s the J31 is a little more aggressive
Old Jan 17, 2006 | 09:32 PM
  #18
drkenan's Avatar
cool...thanks man
Old Jan 17, 2006 | 10:42 PM
  #19
Slowb5's Avatar
pc-16 file is for the 99.5 and below...it runs higher timing advance and lower boost, 19 psi, not sure on the timing. whereas the j31 ( if im correct ) is more boost and less timing advance....24lbs. thus the difference.
Old Jan 18, 2006 | 12:37 AM
  #20
goldenchild's Avatar
GO BIG TURBO! dont waste ur time on something that cost pretty much teh same with half the power. i had one for only 3k miles and got bored and went BT. that turbo is such a waste. for 800 u could get a gt28r or a big *** t3/t4
