Newb k04 question...
Old Oct 2, 2007 | 01:37 PM
ZGSON's Avatar
Default Newb k04 question...
Since k03's are just the stock A4 turbos right?,Are the k04's from another Audi model? Who makes them?Where do you guys get them and how much do they generally run? I searched and couldn't find a good answer and the newbie sticky link doesn't go into too much about them...
Old Oct 2, 2007 | 01:40 PM
ZGSON's Avatar
Default RE: Newb k04 question...
I think I found my answer....
http://www.slowboyracing.com/more.php?id=2183
Old Oct 2, 2007 | 02:27 PM
Audi_Skydiver's Avatar
If you are thinking of going K04, check out this site: www.Gpopshop.com
They take old K03's and remake them into brand new K04-015 turbos. The K03 and K04 use the same turbo housing just different internals. I have one in my car and have not had any problems with it. Plus they are only $625!
Josh
Old Oct 2, 2007 | 02:30 PM
A4speed's Avatar
I wouldn't get the k04 if your planning on getting big hp, the k04 is a k03 with a bigger compressor. i would save up for a gtrs elim. kit and supporting mods, definitely worth it.
Old Oct 2, 2007 | 02:50 PM
ZGSON's Avatar
ORIGINAL: A4speed
Yeah I did see that, but that gtrs is almost 3 times as much. Also, how much are you spending on supporting mods? How involved is that?
Old Oct 2, 2007 | 02:51 PM
ZGSON's Avatar
ORIGINAL: ThePaintballGuy
Josh
Thanks for the info, will check it out. Im picking up my b6 on Thursday, so a turbo isn't an immediate buy but just checking around.
Old Oct 2, 2007 | 02:56 PM
kolan67's Avatar
3x's as much... but 100x more fun
not that i would know
Old Oct 2, 2007 | 03:20 PM
A4speed's Avatar
k04 with GIAC will give you a nice kick but if you really want some power, then save up my friend.
Old Oct 2, 2007 | 04:50 PM
sean1.8t's Avatar
ORIGINAL: ZGSON
ORIGINAL: A4speed
no, the GTRS is only 2 times as much. but as they said, 100x's more fun.
if you get a k04 and basic programming, you'll only see a hp gain of like 30ish over a chipped setup. to see any significant gains you have to get aggressive software. which requires FMIC, injectors, exhaust, clutch, etc... those are all the supporting mods. and those are the same supporting mods for a GTRS..
so really, the difference between a goodk04 setup and aGTRS setup is around $1000 at most.
and you'll be able to acheive 100+ more hp
Old Oct 2, 2007 | 06:50 PM
ZGSON's Avatar
ORIGINAL: sean1.8t
ORIGINAL: ZGSON
ORIGINAL: A4speed
Ok, can I borrow $2000? In all seriousness though, are you guys doing all this on credit cards or are ya'll just such ballers that at any given time you have an extra $2000 to throw at your cars?
