Newbie help needed: ECM Questions
Old Jan 21, 2008 | 06:27 PM
say's Avatar
say
Default Newbie help needed: ECM Questions
Hi, I am trying to save some$ and try to fix my 2000 Audi A4 1.8T FWD myself.
Symptom: AFTER engine is shut off, the secondary air pump continues to run (sounds like a vacuum cleaner), this drains my battery dead by the next day.
Diagnosis: The secondary air pump relay in the ECM is stuck On. Need to replace relay.
Questions:
1) Is this the right relay?
http://www.autopartswarehouse.com/de...3-1641108.html
2) If I remove the electrical harness connected to the ECM. Will I screw something up and need a re-flash?
3) Anyone has a step-by-step instructions (best with pictures) on how to open up the ECM?
Thanks.
Say
Old Jan 23, 2008 | 06:46 PM
CoastalA4's Avatar
Default RE: Newbie help needed: ECM Questions
Looks like the correct relay.
No on a reflash providing you disconnect your battery (neg and pos) terminals. Have your stereo code handy and be prepared to do a TBA when you're done.
You are not going INTO the ECM to replace the relay. It's under the ECM cover, and not in the brain box itself.
No pictures here, sorry.
SFL_A4
Sep 7, 2021 01:41 PM
William_Audi
Jan 24, 2014 04:25 AM
audittquattro
Feb 19, 2012 03:18 PM
Sammydtd
B8 Models
Feb 15, 2009 03:00 PM
steezybme
Apr 1, 2008 08:50 AM
