NEWBIE KO4 ?s
hey i think my insurance is going to fix my car so i will be doing some needed upkeep to my a4. I have a 2000 a4 1.8t trip front wheel drive with 105xxx miles on it. all stock for now. i know that i am going to replace the timing belt, tensioners, etc and buying the parts from audi. the next thing i have read is that the snail or turbine for our cars needs replacing at around 85k? is it true? if so i want to keep my car reliable as possible. so i have heard of a k04. how hard is it to install it into my car? and is the k04 from the newer a4? how much power can i get from it.. do i need to upgrade ecu? what injectors? any info that i need to know?
i tried doing a search on ko4 and the search came up with a lot of no help.. if anyone has input or a link it would be grateful.!!!
Dont buy the parts from audi for your TBelt.. Get it from ECS.com or anywhere other than the dealer.. They are sure to be the most expensive. The turo/turbine/snail should last longer than 85k miles from what ive learned.. If you dont hear anythings bad, or have a real reason to believe something is wrong dont worry about it... Just get GIAC for now, then if the turbo goes later, upgrade to K04 if you want. These cars are slow stock which would make one think that their turbo isnt working right, but get a chip and you will be amazed!
I think with just the k04 youll get around 220 hp and will need a fuel pressure regulator and injectors.. Thats about 20hp more than what a chip will give you, but a chip will still give you about 50 extra hp and 80 tq. I think if you have the k04 and giac software its like 240 hp... Those are just guesses... Im not an expert by any means as far as the k04 setup goes.
ORIGINAL: tommhoang
whats a GIAC? is that a brand of ecu? so do i need injectors witht the ecu or will my stock ones run okay? is it basically just plug and play? thanks
The only other thing you need to get if you get chipped is an upgraded Diverter Valve, the 710N DV is what a lot of people use, its used in the 220hp TT.. About a $35 part and pretty simple to instal yourself.
ORIGINAL: tommhoang
sweet thanks for the input .. looks like my first mod is the ecu and diverter valve. getting it flashed? where can i get that done. and what does it do?
ORIGINAL: onepoint8tee
