newbie question...
Old Jan 22, 2008 | 11:05 PM
CoBra03TerminAtoR's Avatar
Default newbie question...
i am curious... as i read through some of these threadsi see people saying i have a fault code, or somthing of that nature... im wondering if the car itself gives a code on the screen in the car or if these codes are what people get when they use their vag com??
Old Jan 22, 2008 | 11:08 PM
Steel02001's Avatar
Default RE: newbie question...
Anytime your car has a check engine light (and sometimes when it doesn't) and there is something wrong with it there is a code that can be read. You can take it to an autozone or schucks or wherever and they can tell you what that code is (its a number) and that corresponds to a certain problem.
Example, I am new to audi's as well but on older Honda's the ECU would actually blink a certain number of times and that was the code. It is a bit more complicated than that now but same thing overall.
Old Jan 22, 2008 | 11:17 PM
chaos92287's Avatar
vagcom is a program for your laptop. you hook your laptop up to the car via a cable from ross-tech, or the ebay one that's much cheaper but can't log data. you can still check and clear codes tho. you can download the program from the ross-tech website
Old Jan 22, 2008 | 11:19 PM
chaos92287's Avatar
oh and you get codes when you get a check engine light. tho sometimes you can get a code without triggering a CEL
Old Jan 22, 2008 | 11:21 PM
A4speed's Avatar
easiest thing to do is use autozones code reader and they let you use it for free.
Old Jan 22, 2008 | 11:26 PM
hmmm alright thanks guys!!
Old Jan 22, 2008 | 11:27 PM
chaos92287's Avatar
ORIGINAL: A4speed
yeah but the one's around here won't let you clear the codes. and the ebay vag cable is 20 shipped, you'll save that much in gas alone in a few months
Old Jan 22, 2008 | 11:30 PM
A4speed's Avatar
really, the ones at the autozone here clear the codes, i guess it all depends on what scanner they have.
Old Jan 22, 2008 | 11:33 PM
chaos92287's Avatar
nah they're able to, its just a legal thing. some guys are willing to do it, but others won't. but now i dont gotta worry since i got the vag cable
Old Jan 22, 2008 | 11:38 PM
so you only have to have the vag cable? for 20 bucs... what about the program? how much does that run
