Newly Purchased 97 A4 Engine Sound
so if the sound dose continue once the engine is warm dose that rule out the valves? please say yes, cuse i knoiw it has a exhaust leak[:@] also would you guys like a video of the camera paning over the engine and under body? so you could get a visual with sound?
timing sounds a little off. definately a horrible exhaust leak.
like the other guy said i would try a cleaner the next full tank of gas.
sometimes fuel injectors make funny noises when they are dirty.
and it often sounds like valve tapping.
no floating broken things the motor wouldnt be runnin now, id say fix what you know is wrong the exhaust check the manifold for leaks then if thats not it have someone look at your valves
corinmcdonald
Mar 27, 2012 02:20 AM
