nice find for fault codes
Old Dec 12, 2006 | 01:45 PM
T28_A4's Avatar
Default nice find for fault codes
http://ebahn.bentleypublishers.com/AUDI/ ....just put in what car you have and it gives you all the fault codes and what possible parts could be causing this code...you get more info if you buy a subscription, but this gives you a good start
Old Dec 12, 2006 | 01:51 PM
T28_A4's Avatar
Default RE: nice find for fault codes
also, i was wondering if anyone knows the difference between the 2 codes P0172 and P0175 both give the same description but the P0175 says Bank 2 instead of Bank 1...
P0172 16556 System Too Rich Bank 1
Fuel Injectors
Fuel injection system components removing and installing [GST]
Fuel injection volume, fuel injector leakage and spray pattern of injectors, checking
Fuel injectors checking [GST]
Fuel injectors, checking
Fuel rail with fuel injectors, disassembing and assembling
Fuel Supply system
Fuel pressure regulator and residual fuel pressure, checking
Fuel pressure regulator and residual pressure checking [GST]
Fuel Pump (FP) relay -J17- and relay activation, checking
Fuel pump checking [GST]
Fuel pump removing and installing [GST]
N80 - Evaporative Emission (EVAP) canister purge regulator valve
Evaporative Emission (EVAP) canister purge regulator valve checking
Oxygen sensors
Function of oxygen sensor control
Oxygen Sensor (O2S) and oxygen sensor control before Three Way Catalytic Conv (TWC) checking [GST]
Oxygen sensor and oxygen sensor control before Three Way Catalytic Converter (TWC), checking
Oxygen sensor and oxygen sensor control behind catalytic converter, checking
Oxygen Sensor and oxygen sensor control behind Three Way Catalytic Conv (TWC) checking [GST]
Oxygen sensor heater for oxygen sensor, checking
Oxygen sensor signal wire and activation, checking
Oxygen sensors aging, oxygen sensor before catalytic converter, checking
Oxygen sensors, removing and installing
Old Dec 12, 2006 | 01:59 PM
techbod's Avatar
# code explanation
[IMG]local://upfiles/12092/F0CFD7CCA23B48539C4FB04B63A470FB.jpg[/IMG]
Pleaseabulls
Feb 27, 2015 10:47 AM
punjabi
Nov 12, 2009 12:37 AM
raffysaudi
Aug 20, 2008 11:10 PM
meeksy5
Jun 18, 2008 08:51 AM
T28_A4
Jul 18, 2006 07:57 PM
