nitrous
Old Sep 18, 2007 | 01:39 AM
sdboarder84's Avatar
Default nitrous
this is the kit I am looking at. your thoughts
4 & 6 Cylinder Nitrous System
Part #82021
[hr] A complete "Wet" nitrous system. Everything is included for a safe, proper installation. • Designed to work safely on stock type engines, but is also engineered to perform flawlessly on highly modified turbocharged and supercharged combinations. The ideal nitrous system for any fuel injected vehicle.
• All major components are factory pre-assembled inside the "Nitrous Management Unit". Easy, plug and play, two-hour installation.
• ZEX Nitrous Systems have an advanced, patented feature called "Active Fuel Control". This feature monitors nitrous bottle pressure and adds or subtracts enrichment fuel so the engine never runs too rich, or too lean, when you engage the nitrous system.
• ZEX "Wet" nitrous systems activate at wide-open throttle using advanced electronics that monitor your engine's throttle position sensor. This makes using your nitrous system very easy and reliable.
Old Sep 18, 2007 | 02:08 AM
A4speed's Avatar
Default RE: nitrous
have you chipped your car yet? you might want to do a couple other things first?
cincytt said nitrous isnt a bad thing to do to add power, but u might want to work with the internals first and then add the NOS for the finishing touch. just a thought. ill bet it would be sweet as hell when you feel it though.
Old Sep 18, 2007 | 02:14 AM
BadLuckAudi's Avatar
Default RE: nitrous
yea there are alot of better things to do to your car like a chip
Old Sep 18, 2007 | 08:52 AM
The Bishop's Avatar
Default RE: nitrous
I used to have a ZEX system on a different car, it worked really well. You would be fine adding that as long as the fuel is tuned properly. But I too agree, there are better things to spend your money on. Turbo, chip. etc..
Old Sep 18, 2007 | 09:50 AM
oneg's Avatar
Default RE: nitrous
juice is for 2.8's![&:]
Old Sep 18, 2007 | 09:59 AM
ironman's Avatar
Default RE: nitrous
haha 30v all the way
Old Sep 18, 2007 | 12:22 PM
ItsThat2.0T's Avatar
Default RE: nitrous
chip it. no nawzzzz
Old Sep 18, 2007 | 10:51 PM
Default RE: nitrous
Thanks for all of the input. looks like I have some thinking to do.
Old Sep 18, 2007 | 10:54 PM
hiwords's Avatar
Default RE: nitrous
haha like sum1 said b4 "don't think, just do it"
Old Sep 19, 2007 | 12:39 AM
A4speed's Avatar
Default RE: nitrous
ORIGINAL: hiwords
that was so me!
