no hot air
Old Oct 10, 2006 | 11:40 PM
guse111's Avatar
Default no hot air
I have a 96 a4q and now that it is cold out, i turned the heat on and none came out. just the regular cold outside air came in.....this was happening at the end of last winter and sometimes the air would be hot like it should be. do you guys have any suggestion or ideas on whats wrong and how i will need to get it fixed? much would be appreciated
Old Oct 11, 2006 | 12:26 AM
wood_e's Avatar
Default RE: no hot air
Is this after the car is fully warmed up? You might have a clogged heater core
Old Oct 11, 2006 | 12:29 AM
quattrosedan's Avatar
or you could have a bad thermostat like me that is stuck wide open......damn winter is coming......not good...lol
Old Oct 11, 2006 | 12:30 AM
acetrebo's Avatar
Is your coolant level proper?
There may be air in the system, since you say it is intermittent. Does the car overheat?
Check the level, bleed the air out of the system, and see if that helps.
If not, it may be a bad or clogged heater core, a beotch to change, but there are writeups.
Old Oct 11, 2006 | 12:55 AM
guse111's Avatar
yea the air didnt change after 25 minutes of driving and the car does not overheat.
Old Oct 11, 2006 | 01:24 AM
wood_e's Avatar
Thermostat could be stuck open
Old Oct 11, 2006 | 01:29 AM
guse111's Avatar
how would i fix this?
Old Oct 11, 2006 | 01:47 AM
metalmulisha's Avatar
Change the thero!
Old Oct 11, 2006 | 09:23 AM
david9999's Avatar
Possible causes
1. Coolant thermostat stuck open. The car will take a long time to heat up and the coolant gauge will be lower than the middle of the gauge. Fix - replace thermostat
2. Blocked heater core - This can be due to sludge, rust or air. With the car warmed up and the heat on, feel the coolant lines going through the firewall to the heater core. They should both be hot. If they are not then something is blocking the hot coolant from going to the heater. If they are both hot then
3. Could be flap valve. The motors on these can burn out and thus air is not difected over the heater core. Check the HVAC system with a vagcom.
4. All the above assumes that if you set the fan to manual it responds and blows.
Old Oct 14, 2006 | 03:48 AM
Simone's Avatar
i'm having the same problem... thinking its the thermostat.
how easy is the thermostat to replace? anyone have the AW write up on it?
(not hi-jacking, just bumpin!)
