no jets / dirty windshield
Old Mar 2, 2006 | 05:35 PM
impaler2383's Avatar
Default no jets / dirty windshield
I refilled the washer fluid container about a week ago and I could never get the jets going. I figured it was because air got in the pump all that time the container was empty. So I waited and just kept trying to get the jets going figuring liquid would reach the pump sooner or later but it still doesn't work. Does anyone know what it could be?
Old Mar 2, 2006 | 05:39 PM
black991.8tq's Avatar
Default RE: no jets / dirty windshield
there probally dirty ...you can take off the hoses goin to them and use an air gun and blow em out.
Old Mar 2, 2006 | 05:42 PM
Jestnomen's Avatar
6th Gear
That or the pump for the winshield washer is dead. Turn your headlights on, can you get the headlight washers to work? Can you hear the pump kick on when you flip the wiper stalk? If not then maybe a bad stalk?
Old Mar 2, 2006 | 06:00 PM
Thank you, I'll try that after my next class. [:@] Air gun? HA, all I've got are my hands and some weak *** plastic utensils (not home).
Old Mar 2, 2006 | 08:41 PM
The headlight washer doesn't come on and there is no sound from the pump. The wipers come on though. Does this mean that the stalk is good and the signal to the jets is getting lost or that the stalk is bad altogether? Or worse yet, is the pump gone?
Old Mar 3, 2006 | 11:29 AM
Jestnomen's Avatar
6th Gear
Hmmm not sure, I'd say the pump is probably gone. I've posted the procedure to swap the tank out and replace the motors. How handy are you? I'd pull the pump out and jumper it to the battery to see if it will turn on or if it is dead. Do you have a cheap voltmeter? You can pull the harness off the pump and have a friend turn the winshield wipers on. See if you get 12 volts. You can even buy a cheapy 12 volt test light from walmart or whatnot.
Old Mar 3, 2006 | 12:05 PM
Lazydog's Avatar
Last Place - just "necause"
Might want to check your fuses also. I had this problem just resently and had to replace the fuse.
Old Mar 3, 2006 | 02:49 PM
Thanx, I'll try all that as soon as I get home. Where are the fuses again?...I guess it should be in the manual.
Thanks again
Old Mar 3, 2006 | 03:23 PM
drivers side by ur knees....take off the panal
MartinCieslak1
Feb 21, 2011 09:18 PM
larrypzlast
Aug 8, 2010 06:52 PM
nitrogen
Oct 9, 2009 10:59 AM
mbeau003
Apr 12, 2007 01:30 PM
shaggys40oz
Aug 16, 2006 10:49 PM
