no ko4 install?
Old Mar 21, 2006 | 01:49 AM
juice88's Avatar
Default no ko4 install?
ive searched on audiworld, audizine, google, and AF but i still cant find diy install for the ko4. can some1 help a brother out?
Old Mar 21, 2006 | 01:54 AM
xx18quattroxx's Avatar
Default RE: no ko4 install?
just take out the k03 and put in the k04, only diff between the 2 is inducer blade design... you need to pull your lock carrier, and you will need either a deep offset 17mm wrench or a 3/8 drive universal joint to get all the bolts off the exhaust manifold to the turbo. use lots of penetrating oil.
Old Mar 21, 2006 | 01:55 AM
juice88's Avatar
well i would like to have some real instructions before i f something up. ive only done snub install
Old Mar 21, 2006 | 01:56 AM
i have to replace the wastegate on my k03, if you would like i can take pics of the process of getting to the turbo and getting it off/getting around it... not a big deal, just lemme know before i do the wastegate.
Old Mar 21, 2006 | 02:04 AM
PandaXpress's Avatar
i hope this helps you
http://www.atpturbo.com/root/help/pd...ngitudinal.pdf
Old Mar 21, 2006 | 02:18 AM
AHB900's Avatar
are u sure u checked audiworld? :-\ http://www.audiworld.com/tech/eng.html go down a bit its called K04 Turbo Upgrade ic ant link you to the exact page since it does not let me.
Grey2007
Feb 23, 2012 01:17 PM
kevinbednarek
Feb 22, 2012 06:19 PM
Brautty
Jan 21, 2012 12:38 AM
Dave666
Jul 12, 2005 08:47 AM
1996a4
Apr 4, 2005 04:09 PM
