no power on accel
Old Jun 29, 2007 | 11:15 PM
gekabech's Avatar
Default no power on accel
ijust bought my first audi today "2002A4 1.8T 78k miles" I can't hear the turbo? and when i first take off the car won't get out of
its own way. Is the boost supposed to be noticable on this model?
Any help or advise would be great.
Thanks.
Old Jun 29, 2007 | 11:26 PM
a4 1.8t's Avatar
Default RE: no power on accel
get used to it.. haha. try turning ur ac on then starting out.. the turbo is really small and you cant really hear it unless your in a tunnel listening for it or get a cone filter intake. get a reflash its worth the money, about $500
Old Jun 29, 2007 | 11:53 PM
gekabech's Avatar
will the reflash help with the lag? And could it be a DV problem?
Old Jun 30, 2007 | 12:02 AM
Belligerenceâ„¢'s Avatar
you shouldn't ever notice any lag in a stock A4 1.8T. the turbo is tiny, meaning it spools almost instantly. our engines develop their peak torque at a very low RPM, around 2000 or a little less even.
is your check engine light on?
Old Jun 30, 2007 | 12:13 AM
gekabech's Avatar
No cel, andthere is a definite delay in getting power to the ground
Old Jun 30, 2007 | 12:14 AM
gekabech's Avatar
I wonder if the turbo even works.
Old Jun 30, 2007 | 12:21 AM
a4 1.8t's Avatar
you probably have a boost leak. possible the dv......
im not sure on this but, your wastegate could be stuck and your not boosting at all?
Old Jun 30, 2007 | 01:49 AM
gekabech's Avatar
I just went for a drive with the windows down and sounds it makes are a lot more hissing than whining, so
a boost leak might be the culprit.
Old Jun 30, 2007 | 02:24 AM
a4 1.8t's Avatar
most likely is. get a boost gauge, imo every car should have them stock, best way to tell if you have a major leak which it sounds like you do. if you do get one you should be spiking around 9 psi and the vacuum should be aroudn 22hg
Old Jun 30, 2007 | 02:30 AM
gekabech's Avatar
I'll try that tomorrow, thanks for all the help.
ledzepp2994
Jan 30, 2009 01:24 PM
brodieone
Dec 6, 2007 11:23 AM
tarz4play
Sep 14, 2006 09:00 AM
Cheese Eater
Aug 24, 2006 06:12 AM
s4_revolution
Mar 14, 2006 06:57 PM
