no radio reception
Old Dec 10, 2007 | 09:35 PM
r1chp's Avatar
Default no radio reception
My wife has a 2003 drop top with a symphony II radio. The radio has no rececption. Both AM and FMstations are filled with static. I have read the manual andsreach this fourm. I cannot find an answer. I have not added any new equipment. It just stop working.
Old Dec 10, 2007 | 10:56 PM
01afour's Avatar
Default RE: no radio reception
my radio reception sucks too. i think its cause the cars dont have antennas. time to buy some new cd's haha.
Old Dec 11, 2007 | 12:58 AM
treedodger's Avatar
My 2002 A4 has the same problem. AM is all static, and only really strong FM stations come through. After a bit of snooping around, it look like the radio amplifyer is bad (it's located right above the rear window, and also connects the rear window defroster) The annenae is built into the rear window (just like the defroster)
I'm going to try to repair it myself, but I haven't got around to it.
part number 8E5 035 225 D
I haven't priced it at the dealer yet...I'm afraid what they might charge!
Old Dec 11, 2007 | 12:07 PM
cantdrive55's Avatar
I've also heard that windows with a metallic based tint can affect the reception.
Old Dec 11, 2007 | 12:14 PM
auditech79's Avatar
If your having problems with both AM and FM radio reception the diveristy controller is not working correctly. Now it may not just be the diversity controller, especially on a cabriolet which are famous for having HF and ZF (AM and FM) antenna wire problems that run from the radio all the way to the trunk lid where the diversity controller is. What you need to do is take it to the dealer and have it diagnosed. If it were a standard A4 sedan i would tell you to just replace the diversity controller because there is a TSB for them cracking.
Old Dec 11, 2007 | 12:51 PM
newblueA4's Avatar
I have the same problem in 98 hardtop. I've never heard of the diversity controller. I've heard it's the antenna amp that fails. Does this mean I might have to replace both? Do they usually both go bad?
Thanks.
Old Dec 11, 2007 | 01:28 PM
sony's Avatar
I currently have the same problem as well, my AM reception SUCKS!! I'm gonna call the dealer right now and get some warranty work done. NOT IMPRESSED with the wifes 2002 A4 at this point. THank god for warranty, once its done, its gone!!
Old Dec 11, 2007 | 02:44 PM
auditech79's Avatar
ORIGINAL: newblueA4
Thanks.
On the B5 its common for the amp to go out as well but not as much as the diversity controller.
The diversity controller is located behind the driver's side D-pillar on your car so remove the center rear roof trim (pops down) then pop off the D-pillar, check to make sure the wiring is connected the controller (should have a square white and black connector on it) and check the controller itself for any cracks.
Old Dec 11, 2007 | 02:46 PM
auditech79's Avatar
ORIGINAL: sony
You definately have a bad diversity controller on your car because there is the TSB out for your B6 for them cracking.
BTW if you wanna get rid of your audi thats your business, but if you think the audi is garbage go drive a mercedes around for a few months and still tell me the audi is crap.
Old Dec 11, 2007 | 07:40 PM
r1chp's Avatar
Thx,I guess I will take it to the stealer. This should be fun.
