no radio reception
Old Dec 11, 2007 | 10:06 PM
01afour's Avatar
Default RE: no radio reception
whats the d pillar cause i think mine is bad and i may wanna fix it if its easy.
Old Dec 12, 2007 | 09:44 AM
CRAZYHAWK's Avatar
rear lelt roof support
Old Dec 12, 2007 | 02:19 PM
01afour's Avatar
i thought that was the c pillar. but anyway is it in the trunk or inside the car?
Old Dec 12, 2007 | 02:58 PM
auditech79's Avatar
ORIGINAL: 01afour
No, the C and D pillar are very close together, the one by the rear door window is the C pillar, the D pillar goes on the side of the rear window (inside the car)
Old Dec 12, 2007 | 07:17 PM
BOPOH's Avatar
ORIGINAL: auditech79
You definately have a bad diversity controller on your car because there is the TSB out for your B6 for them cracking.
I did some research i didnt find any TSB on that(found lots of other interesting stuff) what would it be under? electrical? and if there is TSB do i just go to dealer and tell them to replace it?
Thanks
Old Dec 12, 2007 | 07:22 PM
auditech79's Avatar
Its a world known part to go bad on the B6, the controller always developes a huge crack accross it, the dealer will know what it is before even pulling it into the shop.
If you wanna take a quick peak at it (easy) just pop down the rear center roof panel (pops down) and you should see a rectangle electrical circuit board looking thing with two single radio antenna wires running into it. Use your flashlight and take a look at it, i guarantee you there will be a crack in it.
Old Dec 12, 2007 | 07:24 PM
M¥§T's Avatar
ORIGINAL: BOPOH
If there is TSB do i just go to dealer and tell them to replace it?
Thanks
2nd that, if there is a TSB on something will Audi fix it if the car isn't under warranty?
Old Dec 12, 2007 | 07:41 PM
  #18
auditech79's Avatar
It depends on what the TSB says, most likely they won't if its not under factory warranty.
The oil sludge TSB i believe is the only one that you won't be charged for if you can show proof of oil change reciepts.
DSMKiller
Sep 22, 2008 08:17 PM
mikebmassey
Mar 3, 2008 07:17 PM
joelew
Jan 30, 2008 03:52 PM
stan_the_man
Aug 1, 2006 07:57 AM
robroma
Feb 12, 2005 12:35 AM
