Nocking noise on braking
Old Nov 22, 2006 | 05:18 PM
curz's Avatar
Default Nocking noise on braking
Hiya hope you can help me iv just brought an m reg a4 1.8 which is great but iv noticed theres a nocking noise in the front when i brake and drop gears down im guessing its something to do with the suspension but am not surehope ya can help! thanks
Old Nov 22, 2006 | 05:23 PM
techbod's Avatar
Default RE: Nocking noise on braking
engine mount
Old Nov 22, 2006 | 05:25 PM
ProOnThaSnow's Avatar
check to see if one of the caliper bolts is loose.
Old Nov 22, 2006 | 05:43 PM
curz's Avatar
thanks ill have a look
Old Nov 22, 2006 | 05:45 PM
onepoint8tee's Avatar
ORIGINAL: avant80@2.6
engine mount
whAT? Whats an engine mount got to do with braking/knocking??? Please explain.
Old Nov 22, 2006 | 05:49 PM
acetrebo's Avatar
Probably Dave thought that because the post mentioned that the noise occurs during downshift in addition to braking.
And he described the sound as a clunk, so I could see it being a motor/tranny mount.
Old Nov 22, 2006 | 05:53 PM
Is this tip or manual?
Old Nov 28, 2006 | 07:42 PM
mudpuppu_94's Avatar
i had a knock comming from my brakes. it turned out that my brakes were rattling around inside my calipers. i replaced the brakes and rotors (cause they were mauled) and havent had a problem since
Old Nov 28, 2006 | 07:46 PM
techbod's Avatar
Default RE: Knocking noise on braking
manual or auto the engine flexes that's why they have rubber mounts and when one breaks down that's when you get the clunk noise, common sense relay
Enonymous
Aug 24, 2010 07:32 AM
rkumar23
Aug 5, 2010 11:31 AM
S_R_N83
Apr 2, 2008 06:32 PM
b6vel
May 22, 2007 11:04 PM
cinescapist
Jan 29, 2006 06:42 PM
