Noise From Driverside Wheel
Old Jan 15, 2008 | 09:42 PM
alphaA4's Avatar
Default Noise From Driverside Wheel
After starting the car and putting the car in gear and starting to drive, whether in 1st or reverse, there is a noise from the front driverside wheel area like a release spring (or some kind of noise) when letting the clutch out. Has anyone heard of this or noticed it before? Is it normal? The noise never happens again when driving after that, only the first time you move forward or reverse when the clutch is released after you start the car.Please letme know if you anything about this. I just bought the car and I amwondering if this is something major or not.
Old Jan 15, 2008 | 09:51 PM
FASTER's Avatar
Tech Slut
Default RE: Noise From Driverside Wheel
cv joint needs grease? not sure of what a spring releasing sounds like tho
Old Jan 15, 2008 | 09:53 PM
alphaA4's Avatar
Not sure what the sond is exactly. Could be spring releasing or slight grinding even, not sure
Old Jan 15, 2008 | 09:55 PM
FASTER's Avatar
Tech Slut
is there grease in the inside if your wheel?
Old Jan 15, 2008 | 10:10 PM
alphaA4's Avatar
I cant feel grease on the inside of the wheel. Im not sure if its something that needs grease, because its not someyhing that happens everytime you shift. It only makes the sound the first time you move after starting the car. After that you can stop and go as many time and the sound no longer occurs, but if you shut off the engine and restart it, the sound will occur the first time you move foward or reverse. I shut down the engine and started it, and everytime it makes that noise the first time you move then never occurs again for the rest of the trip, thats why I was wondering if there is a safety release or something that releases when you first drive your car, maybe something that assists you on a hill so you dont roll backward or some kind of lock on the wheel that releases.
Old Jan 15, 2008 | 11:32 PM
alphaA4's Avatar
Can anybody offer any insight
Old Jan 16, 2008 | 03:58 PM
audi_lade's Avatar
Well my audi makes a werid not grinding but like ratleing noise in first gear only and the dealership said that its not hurting the car. He said to fix it it would cost way to much. So I just left it and 50k later.......nothing!
Cheers
rmr1499
Feb 18, 2014 08:50 AM
jeffreykauffman
Audi Q7
Oct 19, 2010 09:40 PM
MacaveliMC
Dec 2, 2008 09:04 AM
EmoScumBag
Oct 31, 2008 11:18 AM
psantosabn
Dec 21, 2006 02:22 AM
