Noise from Steering Column?
Old Apr 27, 2005 | 12:29 PM
scottlougheed's Avatar
Default Noise from Steering Column?
I have a 97 A4 Quatro 2.8L that has been running great for years. The last couple weeks it has started to develop a noise that is getting worse. When steering at low speeds(less than 5mph) or at a complete stop with it in Drive, Park or Neutral a loud rubbing noise seems to come from the steering column when turning left or right. At higher speeds no noise what so ever. Steering seems fine, except for the noise. Any thoughts?
Old Apr 27, 2005 | 12:35 PM
Jestnomen's Avatar
6th Gear
Default RE: Noise from Steering Column?
does it sound like grinding?
Old Apr 27, 2005 | 01:21 PM
brrman's Avatar
sometimes the coil spring in the steering wheel/column begins to rub. Almost like rubbing two pieces of paper together. It is not detrimental and if you can live with it you are ok. I have it on my car on occasion.
Can you explain the "Rubbing" noise more? Does it sound like it comes from the wheels? Inside the cabi?
Old Apr 27, 2005 | 03:53 PM
BFlan2001's Avatar
check your ps fluid level, you may need to top it off...
Old Apr 29, 2005 | 01:33 PM
I think the sound of rubbing two pieces of paper together best describes it. It doesn't sound like grinding and I have checked th PS fluid. I've had someone turn the wheel while I listened in the engine compartment and it really didn't sound like it was coming from the engine compartment. It really sounds like it is from the steering column. Where is this spring at and can I WD40 it?
sublimer
Sep 9, 2011 04:47 PM
ilackav8
Jan 6, 2010 05:17 PM
Sean Henning
Jan 11, 2008 10:25 AM
raiydas
Sep 13, 2006 07:14 AM
HansBlix
Jun 17, 2006 12:11 AM
