noob with a4
well sorta, it's my fiance's car. She got it a couple weeks ago and I'm already finding things to fix/replace.
I just wanted to say hi and share a couple pics I took this weekend. - Peter
http://img.photobucket.com/albums/v1...4/PSgauges.jpg
http://img.photobucket.com/albums/v1...4/IMG_0084.jpg
http://img.photobucket.com/albums/v1...4/IMG_0083.jpg
http://img.photobucket.com/albums/v1...4/IMG_0080.jpg
http://img.photobucket.com/albums/v1...4/IMG_0078.jpg
http://img.photobucket.com/albums/v1...4/IMG_0072.jpg
http://img.photobucket.com/albums/v1...4/IMG_0081.jpg
Very clean car! Do the clear corner mod.. I put it off for a few months and I dont know why, it looks so much better now. Plus, that mod is basicaly free if you have a drill, needle nose pliars and some sealant and bulbs of your choice if you dont want ambers... What mods do you have in mind? You better chip that thang!
onepoint8tee- Thanks, I would really like to start with some mods soon its just little stuff thats holding things up!!!! Like theres a little clunking noise in the passenger side going over bumps. I looked over the front suspension and all I could find was a little play in the outer tie rod. It was in this part http://img.photobucket.com/albums/v1...tierodcopy.jpg
Like it moved in/out a bit when the wheel was turned so I changed those(last night) with a set of from http://www.blauparts.com and it's still the same.
Thanks for the replies. -Peter
Edit- So I called the dealer and they said it was in to get the upper links replaced on the passanger side(Nov 05). They also inspected the LCAs and said they were ok. So thats probably what it needs now...
Thanks for the replies. -PeterEdit- So I called the dealer and they said it was in to get the upper links replaced on the passanger side(Nov 05). They also inspected the LCAs and said they were ok. So thats probably what it needs now...
