Noobish brake bleeding question
Old Sep 22, 2006 | 04:13 PM
TheJazz7's Avatar
Default Noobish brake bleeding question
Hey all,
So I've never bled my own brakes before, and it's something I'd like to learn to save $$$...I taught myself how to do the pads, and I've already saved a bunch of cash.
The AudiWorld DIY notes that that "a VAGCOM is required for cars equipped with ESP." Just wondering what the deal is what that, I couldn't figure why the VAG-COM is necessary or what should be done with it. The walkthrough I'm referencing is here:
http://www.audiworld.com/tech/wheel139.shtml
Seems to be a fairly easy job though, but I don't want to F-up my master cylinder. Do most of you manually pump the brakes with the help of a buddy, or do you use one of those vacuum pumps? Any other tips or tricks?
Thx
Old Sep 22, 2006 | 04:18 PM
wood_e's Avatar
Default RE: Noobish brake bleeding question
To bleed the brakes I open the bleeder screw, then get a friend and have them push down on on the pedal all the way. Once its to the floor I close the bleeder (to prevent air geting in the system). I repeat this process until when I close the bleeder the pedal is hard. I replaced my brake fluid in this manner.
Start with the wheel farthest from the master cylinder, and work to the one closest to the MC.
Not sure on the VAG. Typically to bleed ABS systems you need a computer, but usually activating the ABD under braking can work too.
Old Sep 22, 2006 | 04:22 PM
techbod's Avatar
I believe the ESP measures the pads thickness so its logged on the ECU but not 100% sure because I don't work on the latest cars Audi do that at rip off prices, although I have changes quite a few in my time I have never needed VAG to reset things, I use a one man bleed setup my self which is very cheap to buy
Old Sep 22, 2006 | 11:50 PM
Trey25's Avatar
I use either the vacuum pump or have a friend help out. Either way its simple.
Old Sep 23, 2006 | 02:38 AM
Ford2Audi6's Avatar
Just make sure you have the cap on the master cylinder when you push down on the pedals and dont put your face over the bleeder when someone pushes the pedal down, that would be brake fluid in the eye, and thats no fun.
badjoke
Nov 21, 2007 02:53 PM
Lsand
Aug 2, 2007 12:29 PM
less_of_me
Jul 11, 2007 04:24 PM
m5racer
Aug 11, 2006 04:29 PM
Madcrazy10
Feb 19, 2006 10:32 PM
