O2 sensors
Old Sep 20, 2007 | 04:01 AM
sdboarder84's Avatar
Default O2 sensors
My car has 96000 on the clock adn I am going to be doing the timing belt this weekend. I also want ot change out the O2 sensors. does anyone know where I can get them?
Old Sep 20, 2007 | 04:04 AM
PandaXpress's Avatar
Default RE: O2 sensors
http://www.ecstuning.com/stage/edpd/...ategory=Engine
they are a good online place, just scroll down a lil
Old Sep 20, 2007 | 09:33 AM
wood_e's Avatar
Change the pre-cat O2s only. The post cat ones don;t do much. ECS is a ripoff (check their shipping prices). Use rockauto.com to gt your sensors
Old Sep 20, 2007 | 11:09 AM
LampyB's Avatar
I ordered 02 sensors from ECS and shipping was like $5...not a ripoff IMO. They've got the cheapest 02 sensors around...I think it's like $114 for each one. I've never been to rockauto.com, check it out and see if they can beat ECS prices.
Also you're supposed to change them both out at the same time. Otherwise you'll have one clean, clear signal going through and being blocked/slowed down by an old sensor. Depending on the condition, if you only change out one of them the old sensor could cause the new one to go bad too. I'd change both while you're at it...no real reason not to.
LampyB.
Old Sep 20, 2007 | 11:32 AM
onepoint8tee's Avatar
ORIGINAL: LampyB
Wtf? Thats not true. What are you basing that info on? How can a bad/dirty post 02 sensor affect the precat 02 sensor?? It cant. The rear 02 sensor is a tattle tale for the pre cat 02 sensor. Has nothing to do with performance/driveability. The only reason to change the post cat 02 sensor is if it is bad-itself and is causing repeatitive CEL's. The precat should be changed about every 100k miles, and thats all you need to worry about. For a B6, ECS does have the cheapest OEM replacement. You could find a universal Bosch 02 sensor that will work on your car on ebay for around $60. Rockauto was advertising $136 just for the universal type.
trickyniki02
Mar 26, 2010 10:10 AM
Andrew149
Feb 17, 2010 10:55 AM
klum00
Feb 2, 2007 06:30 PM
yamie
Dec 22, 2006 04:15 PM
1BADS4
Mar 31, 2006 04:23 AM
