ODB scanner from ebay?
Old Nov 18, 2006 | 04:24 PM
Trey25's Avatar
Default ODB scanner from ebay?
Anyone have one of these? I want a VAGCOM but can't really get one right now. What do you guys think, do they work?
http://cgi.ebay.com/ebaymotors/GS200...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/U280-...spagenameZWDVW
Old Nov 18, 2006 | 04:29 PM
widgget's Avatar
Default RE: ODB scanner from ebay?
If the ladies don't find ya handsome, they should at least find ya handy!
If it does what it says... might not be a bad little tool for $40, but it's use it pretty limited from the looks of it.
Old Nov 18, 2006 | 04:30 PM
onepoint8tee's Avatar
Yeah those are good as long as you can read and clear codes thats all that really matters in a basic OBD tool like that. A lot of them will read codes but not clear, so those look good.
Old Nov 18, 2006 | 04:32 PM
techbod's Avatar
Default RE: ODB scanner from eBay?
the first one I have and no problems it works great the second is the same as the first but in a different case not sure if they work on the 2001 CAN system though, definatlly a must have tool and cheap
Old Nov 18, 2006 | 04:47 PM
techbod's Avatar
they do see and clear the codes I can vouch for that and 40$ is cheap when you consider what the dealers charge to put it on their test gear and the extra charge to turn the CEL off then the lies they tell you of what they really didn't do to screw your wallet ( I worked in the garages so I know ) to be forewarned is to be forearmed
Old Nov 18, 2006 | 05:18 PM
Trey25's Avatar
Thanks for the info guys.
Old Nov 18, 2006 | 07:09 PM
CRAZYHAWK's Avatar
I bought a similar one on E-Bay from E-Bay Store
One Smart Move Inc
They are not selling any now.
Those you're looking at should be good. They should
read the error codes from the 4 computers and clear them.
Old Nov 19, 2006 | 01:30 AM
david9999's Avatar
I bought a real vagcom. Can do logging, programming, check all the electrical systems, radio and ABS which generic OBD systems don't do. Can check engine performance, boost pressure, engine output, and run diagnostic tests etc.
What is more, when I sell my car, I'll put the vagcom on ebay and sell it for 50 dollars less than I paid for it.
So where is the savings in an ebay scanner?
Old Nov 19, 2006 | 08:12 PM
CRAZYHAWK's Avatar
If you don't have a lap top computer, it's the only
way to read and reset error codes.
Old Nov 19, 2006 | 08:15 PM
ORIGINAL: CRAZYHAWK
Unless you get a really long serial extension/usb adapter for your desktop.
fergusfourrings
Mar 11, 2013 09:03 AM
2003audiA4avant
Oct 5, 2012 06:14 AM
millenia
Sep 21, 2008 07:09 PM
tmkforever
Jul 9, 2008 07:53 PM
limptimtim
Jul 2, 2008 02:13 AM
