odd flashing cel
Old Mar 20, 2007 | 03:29 PM
JohnnyBravoA4's Avatar
Default odd flashing cel
I have not had a chance to see what it was. my vag-com is at home but i filled up at the gas station today and like most days i just left my car running and when i was done the cel was flashing.. I should say that while i was pumping the gas the idle was all over the place while i was fueling up.. very odd
Old Mar 20, 2007 | 03:32 PM
CRAZYHAWK's Avatar
Default RE: odd flashing cel
You should turn the engine off when refueling.
Old Mar 20, 2007 | 03:39 PM
Audi_Skydiver's Avatar
Misfire?
Josh
Old Mar 20, 2007 | 03:41 PM
96audia4's Avatar
Its usually pretty bad when the cel flashes...
Old Mar 20, 2007 | 03:42 PM
i figure its ok.. not to worried it flashed then went away, its usually only really bad if it flashes and then stays on..
ill check it tonight when i go home
Old Mar 20, 2007 | 03:46 PM
x1rider's Avatar
If I'm not mistaken, if the engine is running while the gas cap is off, there is some kind of vapor leak detected by the ECU (I had a similar problem when I had a defective gas cap that wasn't sealing properly, my CEL came on and the dealership scanned it, it was some kind of vapor leak DTC).
Old Mar 20, 2007 | 04:04 PM
wood_e's Avatar
Scan it and see what came up. Your fuel pressure might've dropped when filling the car.
Old Mar 20, 2007 | 04:06 PM
onepoint8tee's Avatar
ORIGINAL: x1rider
Yeah that makes sense, and that is pretty much what I sometimestell people that are refueling with their engine running at the same time. They feel so stupid and sometimes run and kill the engine. I love it (No offense johnny, please dont vice my head in your bicepts and flex [X(])
Flashing CEL is a misfire... If your engine is running with the gas cap off, that might cause a pressure drop-possibly reducing flow from the fuel pump to injectors.... Thats my only explanation for it if it went away after you were done fueling.
Old Mar 20, 2007 | 04:53 PM
I like keeping the car running.. keeps the interior nice and warm..
Old Mar 20, 2007 | 08:29 PM
turbo kraut's Avatar
Tech Guru
but in the long run can be bad for the car
car won't cool down in that 5 minutes or so....... also can cause a spark and make the car catch fire
