OFFICIAL: eBay Short shifter installed!
Old Aug 6, 2006 | 12:59 AM
wood_e's Avatar
Default OFFICIAL: eBay Short shifter installed!
First off I would like to say I regret putting off installing this.
To install the short shifter I used this AudiWorld writeup.
I followed it basically to a T until 10b. The bolts mentioned were NOT torx but they were 5mm allem bolts.
http://pictureposter.audiworld.com/73397/bolts.jpg
Once I removed those allen bolts and everything else mentioned I took out the asssembly.
Thats where I went a little off from what the directions said. I just took off the small circlip for the push down reverse spring. Then I removed the larger one holding the plastic ball in palce and removed the whole shifter rod and poped the ball out.
http://pictureposter.audiworld.com/73397/3.jpg
Fast forward here... I couldn't for the life of me get the mentioned clips in step 20. I just left those alone and it seems fine for now.
http://pictureposter.audiworld.com/73397/5.jpg
I used the slot with the largest reduction. I used blue lock tite on the bolt holding the fork to the shifter rod.
After that I positioned it in the can and put everything back together. It was a real bitch to pull the housing back up to put in the 4 10mm nuts. Also, the rectangle washer and bolt combo was also a bitch to install. I used a little ducttape to hold the bolt in place with the washer.Once those were in the install was a breeze.
The whole process took 3 hours. I know... I took my time, and it was a learning experience. To be honest, this has been the best $42 I have ever spent on a car. The shifts are FIRM, percise and REALLY SHORT! This also eliminated a little bit of slop in the stock shifter.
If you're thinking about buying one stop and just get it already!
Old Aug 6, 2006 | 01:05 AM
flyboy's Avatar
Default RE: OFFICIAL: eBay Short shifter installed!
nice to know. I alway thought they would be cheep. lett us know how it holds up.
Old Aug 6, 2006 | 01:16 AM
aRIf's Avatar
Cool. Thanks a lot for the info
Since I'm leaving the country next friday, it'll be my first mod after I came back.
Old Aug 6, 2006 | 03:36 AM
Session101's Avatar
the pics didn't work for me
Old Aug 6, 2006 | 03:42 AM
wood_e's Avatar
yeah, audiworld blows for pics... just go to the link to the diy article
sluggerjd
Sep 11, 2009 01:53 PM
daghstdrummer
Sep 16, 2008 11:21 PM
Dj Spiel
Jul 22, 2008 04:11 PM
drp1489
Jun 12, 2007 06:01 PM
BFlan2001
Jan 10, 2007 07:48 PM
