Oh, BLEEP! I *BLEEPED* up my turbo!
Old May 20, 2007 | 01:53 AM
Amze's Avatar
Default RE: Oh, BLEEP! I *BLEEPED* up my turbo!
Wow man, sorry about that[&:]
Bad luck much?
Old May 20, 2007 | 04:25 AM
Belligerenceâ„¢'s Avatar
ouchies. now I guess we can stop wondering what happens when your turbo attempts to inhale a socket.
K04 time my friend.
Old May 20, 2007 | 09:53 AM
kpatz's Avatar
No K04 for me, I found a brand new K03 on AZ so I'm going with that. I'm going to get the intercooler replaced as well, since that's probably where the turbo droppings ended up.[:'(]
Amze, when it comes to luck, I see the extremes. I'm either VERY fortunate, or VERY unfortunate. I was fortunate when I found my A4 with 15K miles on it a year ago, and unfortunate when it tried to eat my socket.
Old May 20, 2007 | 11:20 AM
kpatz's Avatar
Update, if someone is willing to sell me a K04 w/low miles cheap, I can always resell the K03 I bought...
Apparently the lean issue I've been having is common with APR Stage 1+, so I may be able to kill two birds with one stone.
Old May 20, 2007 | 12:04 PM
onepoint8tee's Avatar
Most people do these kind of things on purpose so they can upgrade to aBT.
Old May 20, 2007 | 05:06 PM
david9999's Avatar
Makes my eech hurt just to look at it.
Old May 22, 2007 | 09:07 AM
kpatz's Avatar
Well, I should be getting the K03 and SMIC tomorrow, so when I take it into the shop on Thursday I'm going to have them do the following:[*]Replace turbo and SMIC[*]Inspect/clean out intake lines and throttle body[*]Change oil, filter and coolant[*]Find out what's causing me to run lean[*]Flush and replace brake fluid[*]Check and change if needed tranny and diff fluid
The last 2 items are just PM things that should be done, nothing to do with the turbo replacement. Anything else I should have them do?
Old May 22, 2007 | 09:11 AM
  #18
akielb's Avatar
sorry if I missed it above but why are you replacing the SMIC? just due to possible shavings? is thats the reason, how do you not know some shavings didn't get into your engine and are in there right now scoring the cylinder walls
Old May 22, 2007 | 09:24 AM
  #19
votblindub's Avatar
whoa-ho-ho-ho-ho! dude, youre lucky that piece didnt fall into the compressor, damn dude. i cant imagine what i'd end up doing if that happened to me. ive got twins to take care of. if u want more power go with the K04, but if you just wana fix it, go with the K03 sport turbo and youll be allright
Old May 22, 2007 | 09:30 AM
  #20
kpatz's Avatar
Yes, I'm replacing the SMIC in case there are shavings in there. From what I've read the chances are good that any larger shavings would be trapped in the IC. I don't know that there aren't any that made it into the engine, that's why I'm going to have them clean/inspect the intake lines. The guy at the shop said that usually any shavings that make it into the engine just go through and out the exhaust. Probably only the tiniest fragments would make it all the way and those would cause the least amount of damage.
Also, I'm not driving the car right now, I have a rental, until I take it to the shop. When I do I'll put it in stock mode and keep it out of boost as much as possible.
