oil change for 2.8
Step 1) remove 17mm drain plug
Step 2) Drain oil
Step 3) Remove filter (right next to the oil pan)
Step 4) Install new filter
Step 5) Put drain plug in and tighten
Step 6) Fill w/ new oil
Step 7) Check for leaks
There's your DIY
Step 2) Drain oil
There's your DIY
Check the level of the oil before you fire the car up... With a new filteryou will put 6qt's of oil into the engine but check it after putting five and a half quarts and go up slowly from there... Give it acouple of minutesto settle to get correct oil level reading...
SMo'
SMo'
ORIGINAL: SMoLiK
SMo'
SMo'
sollyd25
Jun 27, 2008 01:52 AM
