oil change for 2.8
Old Jan 28, 2007 | 11:33 PM
johnstef's Avatar
Default oil change for 2.8
i tried searching though i can not find a DIY for changing the oil on a 2.8l.
Old Jan 28, 2007 | 11:38 PM
wood_e's Avatar
Default RE: oil change for 2.8
You're kidding, right?
Old Jan 28, 2007 | 11:41 PM
johnstef's Avatar
actualy im not...dude there isnt.
Old Jan 28, 2007 | 11:43 PM
david9999's Avatar
Probably no DIY because it is pretty self explanatory. You change it just like the oil on any other car.
Seriously if you have a B5, go to pepboys and buy a Haynes manual for 15 dollars for the Audi
Old Jan 28, 2007 | 11:49 PM
wood_e's Avatar
Step 1) remove 17mm drain plug
Step 2) Drain oil
Step 3) Remove filter (right next to the oil pan)
Step 4) Install new filter
Step 5) Put drain plug in and tighten
Step 6) Fill w/ new oil
Step 7) Check for leaks
There's your DIY
Old Jan 29, 2007 | 01:33 AM
Trey25's Avatar
hahaha funny thread...not that it matters but you forgot about the skidplate.
Old Jan 29, 2007 | 01:39 AM
wood_e's Avatar
^ yeah... that too (step 0.5)
Old Jan 29, 2007 | 01:43 AM
SMoLiK's Avatar
Check the level of the oil before you fire the car up... With a new filteryou will put 6qt's of oil into the engine but check it after putting five and a half quarts and go up slowly from there... Give it acouple of minutesto settle to get correct oil level reading...
SMo'
Old Mar 19, 2007 | 06:27 PM
Cranky Bastard's Avatar
ORIGINAL: SMoLiK
SMo'
5-6 quarts answers my question, thank you!
2003audiA4avant
Jul 13, 2012 09:32 PM
jaymac
Feb 1, 2010 06:24 PM
chefro
Mar 27, 2009 12:14 PM
sollyd25
Jun 27, 2008 01:52 AM
nc 2.7t
Jan 6, 2006 02:54 AM
