Oil Change gone Bad?
Old Nov 28, 2007 | 11:52 PM
fumoazul99's Avatar
Default RE: Oil Change gone Bad?
so auditech79 do you think i should be worried?
cause i was going to wake up tomorow morning around 6am and take a look at it for my self...
Old Nov 28, 2007 | 11:53 PM
auditech79's Avatar
Just look under the coolant resivior where the filter is and see if the filter is tight, shine your flashlight down there and see if they cleaned the oil off the subframe, if they didn't get some brake cleaner and wash it all off and take off your belly pan and clean it because its probably soaked in oil now.
Old Nov 28, 2007 | 11:57 PM
fumoazul99's Avatar
yah they deffilnatly didnt attemt to clean the subframe... its all drenched in oil... now it kinda looks like oil sludge... but do you think i should do all that cleaning tomorow mornign as soon as i wake up or i can drive on it and do it on friday with more time on my hands
Old Nov 29, 2007 | 12:01 AM
auditech79's Avatar
Just make sure the oil level is ok, if the oil drain plug or filter were loose it would be leaking a lot.
You could probably wait until friday
Old Nov 29, 2007 | 12:05 AM
fumoazul99's Avatar
alright thanks man... im going to check the oil level tomorow morning...
as for them bastards at speedee oil... do you think i could get a refund out of it if i complained?
Old Nov 29, 2007 | 12:09 AM
auditech79's Avatar
ORIGINAL: fumoazul99
Not worth it, plus the receipt you have is worth its weight in gold if you ever get sludge.
Old Nov 29, 2007 | 09:04 AM
CRAZYHAWK's Avatar
Buy a new dipstick.
Old Nov 29, 2007 | 09:45 AM
  #18
Papachristou's Avatar
yes, a dipstick is cheap and the foundation of making sure your car has blood....
I try to wipe up as much oil as i can but i still get a few small puddles it seems for the first few days.... it runs down behind the engine and u just cant wipe it all up.. its on a b6 though
Old Nov 29, 2007 | 11:11 AM
  #19
fumoazul99's Avatar
thanks for all the help... i feel relieved now... i checked my oil level this mornign and it was fine... even tho my dipstick is broken... but i knew where it should be from before...
ecstunning.com it is for the new dip stick!
ok i have a question on what to get.... should i get the dip stick,the funnel thing that the dip stick goes through, and the extension tube? im not really sure what exactly is broken... [&:]
Old Nov 29, 2007 | 12:32 PM
  #20
M¥§T's Avatar
My guess would be that since you said there was oil on the filter, they probably left the gasket of the old filter on...if it sticks to the spindle and you dont take it off, you will leak tons of oil. I used to work for jiffy ube and that was a common problem with the morons that worked there. I would take the filter off and make sure there is only one gaske on there. Then i would still call them and raise hell.
