oil change help
The most common problem people have when changing their oil for the first time is locating the oil drain plug.
Once you get your skidplate/flimsy plastic off from under you car, the oil drain will be very close to the front end of the car.
The bolt with KKB on it is the drain plug. I think it's a 17mm. The part that is disconnected in the pic is the oil return line from the turbo- Don't mess with that unless you are taking your turbo out. I disconnected mine because I was installing a new turbo.
sollyd25
Jun 27, 2008 01:52 AM
