oil leaks
Old Mar 23, 2004 | 12:24 PM
3Audis's Avatar
Default oil leaks
<FONT face="Arial, Helvetica, sans-serif" color=black size=2>Hi, new here and I need some help. I have 3 Audis, '97 A4, 2000 Allroad, 2001 A6, the A4 and the allroad have developed oil leaks, both from the valve cover gaskets and the allroad compunded by the timing chain adjustment gasket leaking. has anyone elseexperienced these problems. Neither car ever had any engine work. HELP!</FONT>
Old Mar 24, 2004 | 10:29 PM
hb972.8q's Avatar
Default oil leaks
ya my 97 is leaking not to bad but need to be fixed soon. about every 2500 miles a quart is needed. i am just to lazy to have it fixed
Old Jan 13, 2005 | 09:02 AM
cinsco21's Avatar
Default RE: oil leaks
Yes, we've had this problem too - repeatedly - have an 1998 A4 Quattro wagon - the valve cover gaskets were replaced under warranty at 31,800, again at 60,000 and now leaking again at 80,000. Also have continuing problems with control arms. Audi has been the most repaired car we've ever had - for the price you pay and the reputation Audi wants to have as an upscale luxury car, I think they could do much better to keep their customers coming back. I like this car, and usually hang on to cars a long time, but will problem never buy another one because of reliability! When you pay this much for a car, it should be much more dependable and when there is a known problem that so many Audi owners are experiencing, Audi should get with it and make the customers happy.
Old Jan 13, 2005 | 06:22 PM
Jestnomen's Avatar
6th Gear
Well the valve cover gasket is very easy to fix yourself if that's what you want to do.
Old Dec 10, 2005 | 07:04 PM
cinsco21's Avatar
Hi I'm back again with the valve cover gaskets leaking again!!!!! In September we had the following done: "Replaced cam tensioner seal per previous diagnosis, remove and replace valve cover gaskets, cam seals and plugs and tensioner gasket." About a month after this was done, that old smell of burning oil was back and sure enough, it is leaking again!!! This will be the fourth time these have been replaced. Any suggestions before we call for service??? This is a 1998 A4 Quattro wagon. I love how this car drives, but it is breaking the bank! I hate to even look at all the money we have put into this car.
Old Dec 10, 2005 | 07:15 PM
tip5's Avatar
Audi's are pretty much a labor of love man. I swear to god ive replaced every part on mine cause the original has broken or just is worn out to hell. Just last month i replaced my control arms and put on all around new bilstein touring cup shocks. And one of my motors on my rear windows burned out. Pain in the *** but a labor of love. I do agree for the name audi is putting out there there not doing a very good job but im speaking from an older 97 a4 maybe the new ones have better quality and engineering. But from what ive heard maybe not.
Old Dec 10, 2005 | 11:23 PM
david9999's Avatar
If this is the 4th time the valve cover gaskets are being replaced for leaking oil then one of the following is the problem.
The person replacing the gaskets is not doing it properly,
The valve cover and mating surfaces are not straight, or clean
The oil leak is not coming from the valve cover gaskets.
Old Dec 10, 2005 | 11:51 PM
sandman's Avatar
yea my valve covers were leaking and i changed them, i think its a common problem.
Old Dec 11, 2005 | 02:31 AM
Slowb5's Avatar
yeah, ive got one nasty oil leak, and it takes about 1 quart every 130 miles....headgasket?
Old Dec 11, 2005 | 12:00 PM
AudiTech04's Avatar
Valve cover leaks..or what looks like a valve cover leak are very common
But not 4 times there is def somthing wrong here
Tell the dealer your not paying this time when you take it in
