OIL OVERHEATING
Old Nov 12, 2007 | 05:50 PM
trin_007's Avatar
Default OIL OVERHEATING
When stuck in traffic our oil temp exceeds 100 (C)which makes the water temp rise to 110. Until recently the max oil temp was 60-70 and it has only recently started getting up to 100 or so. We took the car to the Audi dealer who ran the diagnostics on it and came back with replacing the oil sensor which we did but the problem remains!!!! When the tech replaced the oil sensor we were advised that the oil temp should not exceed 65. Also, when the temp does rise, the engine starts to lose power so something is not right here. Any suggestions about where to look, as the car does not use any coolant and on long runs and highway is fine????.
Old Nov 12, 2007 | 06:01 PM
auditech79's Avatar
Default RE: OIL OVERHEATING
ORIGINAL: trin_007
Come again? Where the hell are you in the world and what engine do you have?
Old Nov 12, 2007 | 06:40 PM
trin_007's Avatar
We are in Queensland , Australia with a 1997 2.6ltr A4.
Old Nov 12, 2007 | 06:56 PM
auditech79's Avatar
100C is the correct temp for the oil, it should always be around 100 at normal operating temp, if it somethimes stays below that you probably have a problem with the thermostat. Im not familiar with the 2.6 motor because its not in the states, i would have them run the fault codes again, it shouldn't affect performance.
Old Nov 12, 2007 | 08:01 PM
Belligerenceā„¢'s Avatar
ORIGINAL: auditech79
ORIGINAL: trin_007
auditech - I think when he said the car "does notuse any coolant", he meant to say he doesn't notice any drop in the coolant level. at least that's the way I understood it. [8D]
Old Nov 12, 2007 | 08:09 PM
auditech79's Avatar
I know what he meant, but he didn't tell me where he was from. If he was from iceland or something then running just water could run him into some problems, wouldn't you think?
Old Nov 12, 2007 | 08:23 PM
Chill72's Avatar
Member
It sounds to me like the thermostat needs to be replaced.
Old Nov 12, 2007 | 09:18 PM
ah yes, I hadn't thought of that. good point!
Old Nov 12, 2007 | 09:28 PM
FASTER's Avatar
Tech Slut
this is no racecar... its not like hes running straight water in his daily driver, maybe a little WaterWetter in there too
Old Nov 13, 2007 | 12:35 AM
trin_007's Avatar
Just to clarify -we don't ever have to top up the coolant - since replacingthe radiator that is. The fan, water pump and thermostat have also just been changed (along with the timing belt) but the problem persists. The Audi tech also expected the car to lose coolant when the temp rose but this is not the case. And we are running 100% premixed coolant.
PS - I say 'we' because I'm a 'she' and my husband feeds me the info......appreciate any help (with the car that is [8D])
