Oil pressure light on
Old Mar 1, 2007 | 01:41 AM
lfab500's Avatar
Default Oil pressure light on
Oil pressure light came on today.I changed the oil 300 miles ago and it is clean. No engine noise. My question is can I use VAG-COM to check oil pressure before I take it to the shop? (New to VAG-COM)
Old Mar 1, 2007 | 02:47 AM
wood_e's Avatar
Default RE: Oil pressure light on
might be the oil pressure switch - Cheap enough to replace and see if everything is OK.
Old Mar 1, 2007 | 04:02 PM
david9999's Avatar
Vagcom doesn't log oil pressure unfortunately. I'd have the oil pressure checked at a garage ASAP. If you have a 1.8T you may have sludege. If you can show that you have changed the oil every 5K miles Audi will cover you.
Old Mar 1, 2007 | 06:10 PM
oh1a4's Avatar
2nd on the sludge - if you are 1.8t, are you using only full synthetic, changed no longer than 5K?
best way to know for sure is to open her up and check the top end for black goo.
Old Mar 1, 2007 | 06:30 PM
wood_e's Avatar
Do you guys even read the thread? He has a 12v....
Old Mar 1, 2007 | 07:56 PM
david9999's Avatar
Ooops, missed the sig at the bottom.
Still have the oil pressure checked quickly Better to pay 50 bucks to find out that it is the sender than to trash the engine by assuming that the switch is the problem and oil pressure is OK.
Old Mar 3, 2007 | 01:33 AM
lfab500's Avatar
Thanks, well I started the car after letting it sit for a few days, no oil light now, but a fair puddle of oil underneath thepan. Can't really tell where the leak is....off to the shop...
Dallas09
Aug 30, 2011 05:57 PM
donsandro
Jun 22, 2011 07:11 PM
ArmenB
Oct 11, 2008 12:23 PM
