Oil Pressure Light stay on... What would cause this???
I just changed out my dash cluster on my 96 A4 because my old one was missing a ton of lights and just about stopped working all together. Whe I put the new cluster in I noticed that everything now working including the dinging sounds... but when I hold it at about 2300 RPM the Oil Pressure Light goes on and stays on. I checked the oil level and it is only about 1/2 quart low.
What would cause this? How do I fix it?
well then your oil pressure is low.... sorry if that sounds condisending but it seems rather obvious heh. Anyways, could be a clog somewhere, or your oil pump, or a bad sensor...
I did a full synthetic Mobil 1 oil change on it yesterday with a Mobil 1 Oil filter and also ran a engine flush through it before I did the oil change. Light still comes on and stays on when driving... sit at a light and it goes off... once I get to 1800 rpm then it goes on again. The light from the old cluster was taken out. Next week I am going to be getting a Oil Pressure gauge and a air/fuel gauge for my A-Pillar
