Oil Pressure Light stay on... What would cause this???
Old Oct 17, 2006 | 01:56 AM
LoveMyAudiA4's Avatar
Default Oil Pressure Light stay on... What would cause this???
I just changed out my dash cluster on my 96 A4 because my old one was missing a ton of lights and just about stopped working all together. Whe I put the new cluster in I noticed that everything now working including the dinging sounds... but when I hold it at about 2300 RPM the Oil Pressure Light goes on and stays on. I checked the oil level and it is only about 1/2 quart low.
What would cause this? How do I fix it?
Old Oct 17, 2006 | 07:21 AM
techbod's Avatar
Default RE: Oil Pressure Light stay on... What would cause this???
faulty sender unit or it might need an oil and filter change
Old Oct 17, 2006 | 11:22 PM
Changed oil and filter today and ran a oil flush cleaner threw it also. Light still comes on.
Old Oct 17, 2006 | 11:28 PM
chuckievi's Avatar
well then your oil pressure is low.... sorry if that sounds condisending but it seems rather obvious heh. Anyways, could be a clog somewhere, or your oil pump, or a bad sensor...
Old Oct 18, 2006 | 10:47 AM
david9999's Avatar
Im concerned about low oil pressure. Have the car taken in to check the oil pressure before your engine is toast.
Old Oct 18, 2006 | 12:09 PM
acetrebo's Avatar
maybe its been low for a while, and the old cluster just wasn't showing you.
Old Oct 18, 2006 | 01:54 PM
onepoint8tee's Avatar
SSSSSSLLLLLLLUUUUUUUDDDDDDDGGGGEEEEEE.
Or
Sensor....
Dont ignore it.
Old Oct 18, 2006 | 02:49 PM
BadLuckAudi's Avatar
yea Id look in to it further it could be some big probs
Old Oct 19, 2006 | 12:33 AM
S_R_N83's Avatar
DONT DRIVE THE CAR
You may have sludge. Do you use synthetic oil?
Old Oct 19, 2006 | 03:09 AM
I did a full synthetic Mobil 1 oil change on it yesterday with a Mobil 1 Oil filter and also ran a engine flush through it before I did the oil change. Light still comes on and stays on when driving... sit at a light and it goes off... once I get to 1800 rpm then it goes on again. The light from the old cluster was taken out. Next week I am going to be getting a Oil Pressure gauge and a air/fuel gauge for my A-Pillar
