oil pressure, maybe?
Old Sep 14, 2006 | 04:51 PM
skibum0019's Avatar
Default oil pressure, maybe?
hey everyone,
So, I got the oil can on my display and a few beeps this morning. The manual says that it's an oil pressure problem. There's also a light "ticking" sound when I start the car that I've recently noticed. Does this sound like a failing oil pump, or could it just be the oil pressure sensor?
thanks!
Matt
Old Sep 14, 2006 | 05:06 PM
Dj Spiel's Avatar
Default RE: oil pressure, maybe?
Both or maybe just one
A OIL Pressure gauge might be a good investment.
Old Sep 14, 2006 | 05:31 PM
skibum0019's Avatar
you're probably right....
how do you hook one of those up, and what's the optimal pressure that you're looking for?
Old Sep 14, 2006 | 05:44 PM
techbod's Avatar
Old Sep 14, 2006 | 06:50 PM
wood_e's Avatar
So with an electric gauge you basically hook into the oil pressure sensor wiring?
Old Sep 14, 2006 | 06:58 PM
techbod's Avatar
correct
Old Sep 14, 2006 | 07:03 PM
techbod's Avatar
just ensure you get the right gauge ( electric ) because there are 2 types and one is mechanical where you would need to change the sensor so it has an oil feed pipe to the gauge from the sensor so more expensive and a sod to fit
Old Dec 2, 2006 | 09:00 PM
alyciell's Avatar
Hi Matt,
I started to experience the same problem a few days ago. As soon as a take off, the oil pressure light comes on and beeps for a while. I also noticed that the oil temperature thermostat does not move at all. Can you tell me what worked for you?
Thanks,
Alicia
Old Dec 2, 2006 | 09:15 PM
CRAZYHAWK's Avatar
Check the dip stick. This could be a sludge problem.
Old Dec 2, 2006 | 09:27 PM
S_R_N83's Avatar
Could be sludge! You shouldn't drive the car with the red oil can coming on AT ALL. I'd tow it to Audi and have them look at it.
