oil question
Old Sep 14, 2005 | 03:10 PM
TexasAudi's Avatar
Default oil question
when is the oil change light suppose to come on? every 3k miles, every three months? what triggers the light to come on?
Old Sep 14, 2005 | 03:43 PM
jaustin's Avatar
Member
Default RE: oil question
wow, no idea I didnt even know I had an oil light..
I have seen a service thing in the mileage area pop up before but that was after I drove 10k
Old Sep 14, 2005 | 03:46 PM
TexasAudi's Avatar
well im sure there has to be an oil light, something to remind you to get your oil changed
Old Sep 14, 2005 | 03:52 PM
jaustin's Avatar
Member
I think what I said is the oil light type of a thing. But that goes off every 10,000 or something.
but I might be wrong
Old Sep 14, 2005 | 04:08 PM
Cheese Eater's Avatar
one of my friends manages an audi dealership/garage outside of Frankfurt and I asked him about oil changes and inspection cycles he said over here (Germany), it's all incorporated into one inspection/servicing that is audi recommended at every 30,000 km. (approx 18,000 mi.)
Old Sep 15, 2005 | 12:59 AM
TexasAudi's Avatar
ive always been told to change the oil every three thousand miles, but thats american cars and not syntheic, so how often should i change my oil in the audi
Old Sep 15, 2005 | 08:09 AM
david9999's Avatar
There is a service light that comes on. Depending on the year/ I believe it comes on every 5K miles. It is triggered by mileage since the system was last re-set.
Old Sep 15, 2005 | 05:28 PM
TexasAudi's Avatar
thanks david your always helpful
Old Sep 16, 2005 | 12:54 AM
CRAZYHAWK's Avatar
On the 2001, there is a "service" display that comes on around every 8,000 mi. The interval depends on how you drive. They do not assume you are using synthetic engine oil. With oils that meet ACEA A3 or A5 you should be able to go 10,000 mi. between changes.
Old Sep 16, 2005 | 01:55 AM
headshok2002's Avatar
ORIGINAL: CRAZYHAWK
Not worth the risk of going 10K miles with the known sludging issues in the 1.8T's... if you're used to changing it every 3K miles, then keep it up! I (as well as many others here) use full synthetic, and change it religiously every 3000 - 3500 miles.
