Oil sensor confusion?!....
Old Jul 3, 2006 | 02:13 PM
dhirsty's Avatar
Default Oil sensor confusion?!....
My car recently ditched all its oil thanks to a not-so-good service, and in trying to ensure that it is checked over satisfactorily I have had two seaparate Audi garages give contradicting advice -
One states that if the oil pressure dropped below a set limit, the oil sensor would recognise this and cause the engine to stop/stall, though this would not work in the case of a mass loss of oil (in the case of the sump plug thread coming loose).
The other garage stated that a loss of oil/pressure would only bring on the oil warning light (a far more believable explanation).
Can someone clear up this confusion please?
Unfortunately the engine started to make a knocking noise before I was able to pull off the road - any advice as to how I can ensure they fix the problem correctly? (rather than just fill it with thicker oil/STP).
Thanks,
DH
Old Jul 3, 2006 | 11:34 PM
david9999's Avatar
Default RE: Oil sensor confusion?!....
AFAIK there is no safety kill on the car for low oil pressure.
Sounds like you need an engine rebuild, new bearings. If the oil change was done at a garage/oil change shop, contact them ASAP. If they give you issues, get a lawyer.
ILoveSun
Oct 19, 2014 07:36 PM
WhosJbags
Oct 22, 2013 09:49 PM
Piperalpha
Aug 18, 2010 11:46 PM
ziglit123
Oct 28, 2008 05:25 PM
JJ Cleghorne
Dec 12, 2007 12:44 PM
