oil smell???
Old Mar 23, 2007 | 02:27 AM
JohnnyBravoA4's Avatar
Default oil smell???
yea so when im under boost after it spools down i get an oil smell, not a buring smell, its like if you drained your oil and just took a wiff of the oil.. I have no clue what it is.. im not down any oil, im not smoking and i have no loss of oil or no visible signs of any oil anywhere.. its been like this for the las two days..
what gives..
Old Mar 23, 2007 | 05:28 AM
Audi_Skydiver's Avatar
Default RE: oil smell???
I am having the same problem. Thought it might be normal so didn't say anything. But sounds like it isn't. YEAH I WANT TO KNOW TO!!!
Josh
Old Mar 23, 2007 | 05:29 AM
Oh and I can smell it through my vents. And outside the car. Just thought i would add that in. Is that how yours is to J.B?
Josh
Old Mar 23, 2007 | 05:32 AM
khj677turbo's Avatar
I dunno, but i get an oil smell too, but its obvious, it comes from the top of the motor block, the top most seal leaks oil and i need to replace it.
Old Mar 23, 2007 | 11:10 AM
x1rider's Avatar
Perhaps a bit of leakage from the valve cover gasket, causing a tiny quantity of oil to drip on the exhaust manifold, causing the oil smell???
Old Mar 23, 2007 | 11:44 AM
BaconBait's Avatar
ORIGINAL: x1rider
That's exactly what happened with mine.
You may want to replace your cabin air filter and spray some lysol into the air inlet with the filter off.
Old Mar 23, 2007 | 12:32 PM
well my valve cover has been leaking since i bought the dam car and this is a new smell.. I would say yes to the dripping on the manifold but its not a burning smell at all it just smells like oil and for me i only get it when i romp on the gas.. i mean i guess it could be from the valve, it smells the same as if you were to open the oil cap and take a wiff..
Old Mar 23, 2007 | 12:48 PM
x1rider's Avatar
Leakage from the crankvent system maybe (torn hose, leaking pancake valve, etc.)??? I know on my 2002, there was a recall on the hose circled in red, they were known for splitting. A little bit of blowby oil can get out there if there is a crack in the hose.
Old Mar 23, 2007 | 01:13 PM
wood_e's Avatar
^ +1 on checking the PCV system...
Old Mar 23, 2007 | 01:20 PM
ill give it a shot.. also i might not be oil.. im not sure now.. i overfilled my coolant tank.. I guess that could be it as well that g12 smells funny.. might be leaking out just a bit when i hit the gas hard.. i dont know..
