Sponsored by:
Sponsored by:
oil smell???
Old 03-23-2007, 02:27 AM
JohnnyBravoA4's Avatar
Default oil smell???
yea so when im under boost after it spools down i get an oil smell, not a buring smell, its like if you drained your oil and just took a wiff of the oil.. I have no clue what it is.. im not down any oil, im not smoking and i have no loss of oil or no visible signs of any oil anywhere.. its been like this for the las two days..
what gives..
Old 03-23-2007, 05:28 AM
Audi_Skydiver's Avatar
Default RE: oil smell???
I am having the same problem. Thought it might be normal so didn't say anything. But sounds like it isn't. YEAH I WANT TO KNOW TO!!!
Josh
Old 03-23-2007, 05:29 AM
Oh and I can smell it through my vents. And outside the car. Just thought i would add that in. Is that how yours is to J.B?
Josh
Old 03-23-2007, 05:32 AM
khj677turbo's Avatar
I dunno, but i get an oil smell too, but its obvious, it comes from the top of the motor block, the top most seal leaks oil and i need to replace it.
Old 03-23-2007, 11:10 AM
x1rider's Avatar
Perhaps a bit of leakage from the valve cover gasket, causing a tiny quantity of oil to drip on the exhaust manifold, causing the oil smell???
Old 03-23-2007, 11:44 AM
BaconBait's Avatar
ORIGINAL: x1rider
That's exactly what happened with mine.
You may want to replace your cabin air filter and spray some lysol into the air inlet with the filter off.
Old 03-23-2007, 12:32 PM
well my valve cover has been leaking since i bought the dam car and this is a new smell.. I would say yes to the dripping on the manifold but its not a burning smell at all it just smells like oil and for me i only get it when i romp on the gas.. i mean i guess it could be from the valve, it smells the same as if you were to open the oil cap and take a wiff..
Old 03-23-2007, 12:48 PM
x1rider's Avatar
Leakage from the crankvent system maybe (torn hose, leaking pancake valve, etc.)??? I know on my 2002, there was a recall on the hose circled in red, they were known for splitting. A little bit of blowby oil can get out there if there is a crack in the hose.
Old 03-23-2007, 01:13 PM
wood_e's Avatar
^ +1 on checking the PCV system...
Old 03-23-2007, 01:20 PM
ill give it a shot.. also i might not be oil.. im not sure now.. i overfilled my coolant tank.. I guess that could be it as well that g12 smells funny.. might be leaking out just a bit when i hit the gas hard.. i dont know..
Quick Reply: oil smell???
