ok got my apr chip and need some help please!
Old Jun 27, 2006 | 04:29 AM
ibe3pac's Avatar
Default ok got my apr chip and need some help please!
ok so i went to palo alto last thursday to pick up my new cross drilled rotor and to drop of my ecu to get the chip soldered in and later i found out that they wouldnt get my ecu back till today. so to make a long story short i got my new rotors and brakes on no problem and they look really good then i put my ecu back in left my ignition on for about 5 min with the battery on a charger and then tryed to start my car! well didnt ******* work! anybody have this problem? can anybody please help i called the guys and the manager said to call back later and just gave a me a big ? mark bc well hes a **** tard please help i want my car back!
Old Jun 27, 2006 | 09:12 AM
david9999's Avatar
Default RE: ok got my apr chip and need some help please!
Not sure why it took them so long to do your chip? It is a 15 minute job.
Disconnect the battery, and recheck the connection at the ECU. Then reattach the battery, do a throttle body adjustment and you should be good to go.
Old Jun 27, 2006 | 12:10 PM
ShaodwMav's Avatar
how do u do a tb adjustment???
Old Jun 27, 2006 | 01:24 PM
onepoint8tee's Avatar
ORIGINAL: ibe3pac
I dont think thats the right way to do it. Hope you didnt fry anything, such as your ecu by doing that.
Old Jun 27, 2006 | 01:33 PM
JohnnyBravoA4's Avatar
thats how you do the throttle body adustment you put the key in the on position right b4 you make the full turn that would turn the car on, you will hear some clicking and some other interesting noises thats the throttle body, and then eveything should work just fine.. Ill see if i can find the APR insalation crap i got dont know if i still have it..
Old Jun 27, 2006 | 01:41 PM
ORIGINAL: JohnnyBravoA4
He said he had a battery charger hooked up to the battery while the ignition was in the on position... I dont think your supposed to charge your battery with the ignition on, or with the +/- cables from the car hooked up to it at the same time.
Old Jun 27, 2006 | 04:04 PM
david9999's Avatar
I doulbt that the battery charger with the battery connected would be a problem.
I think either there was a soldering problem or the ECU isn't installed correctly
Old Jun 27, 2006 | 04:09 PM
my bad i didnt read that part.. yea that not a good move..lol
Old Jun 27, 2006 | 04:51 PM
ibe3pac's Avatar
and the car is turning over it just wont go! right now i have the ecu out of the car battery disconnected and a charger on the battery bc its not very charged! but anyway im going to give it one more shot from the top and if it doenst work im drving back to palo alto and yelling at some people to make my car go!!!!
Old Jun 27, 2006 | 04:58 PM
clconversion's Avatar
how long was the car sitting maybe the battery is just dead and you said the charger wasn't charging it ?
