ok pinpointed the problem. still need help/suggestions..brake light issue
Old Mar 11, 2006 | 10:58 AM
bluovalguy's Avatar
Default RE: Can anyone help me with this problem? getting brake light malfunction? but they work
I had the dealer look at mine when I took it for the 5000 service. They said they replaced a connection, it worked for about a week then started again. But it is very intermittent. Sometimes it will go for weeks with no problem, then one day it never works, then it is fine again. I will have them look at it again soon.
Old Mar 11, 2006 | 11:12 AM
A4 the Quattro's Avatar
ORIGINAL: bluovalguy
so the only way to drown out the annoying beep, is turn up the Bose
thats been my solution thus far
Old Mar 11, 2006 | 11:30 AM
dafrazi's Avatar
Default RE: ok pinpointed the problem. still need help/suggestions..brake light issue
I suggest that you check the brake switch too. Should be connected down behind at the brake pedal.
Old Mar 11, 2006 | 11:32 AM
bluovalguy's Avatar
If that were the case, wouldn't all of the lights be acting up?
Old Mar 11, 2006 | 12:13 PM
new update...
my girlfriend just noticed when she was in front of me that.. when my lights are off.. and i apply the brakes.. the front right parking signal lights up.. that explains the headlight failure warning...
i guess i need to take and get the wiring and/or relays checked out..
Old Mar 13, 2006 | 10:08 AM
dafrazi's Avatar
Normally yes. but it's easy to check and eliminate as a possible cause.
Old Aug 2, 2011 | 01:16 AM
Baga's Avatar
Originally Posted by A4 the Quattro
new update...
I know this is kind of an old post, but did you ever get this issue resolved. I am currently having the same issue, so weird. It started happening after a brake light warning light came on. So I changed my brake lights and all of a sudden the same issues you mentioned in this post has been happening. Any resolution?
wigadore
Sep 21, 2011 06:32 PM
branstone
Nov 2, 2010 11:58 AM
chenn
Feb 16, 2010 11:29 AM
pho1n1x
Jun 10, 2007 01:02 AM
SteelCitySupra
Nov 27, 2004 05:51 PM
