OK! /Sercive! huh?
Old Nov 22, 2006 | 07:27 PM
CRAZYHAWK's Avatar
Default RE: OK! /Service! huh?
On my 2001, I press button A and turn key part way not cranking, I
continue to hold "A" and then also press "B".
Old Nov 22, 2006 | 07:30 PM
Riko's Avatar
okay well what is the diff between the inspection service light and the OEL-OIL service light. cause mine def isnt the OEL-OIL light, at least it doesnt say OEL-OIL, just says service!. So is mine jsut the inspection serivce light? and what does that mean?
Old Nov 22, 2006 | 07:34 PM
techbod's Avatar
basically its a time delay you have to clear one then do it again for the second code ( you have to break the first wall down to sort the next ) standard procedure that's what confuse many
Old Nov 22, 2006 | 07:42 PM
CRAZYHAWK's Avatar
My 2001 only has a "service" reminder. With your left hand, palm down
press the right button with you thumb. Hold it and turn the key part way.
With your left pointer press the left button. This should clear the "service"
reminder. It should indicate 10,000 mi.
