Other Wierd Starting Problem Theard
Old Jun 30, 2007 | 04:08 PM
93Akkord's Avatar
Default Other Wierd Starting Problem Theard
Ok...well from the research I've done its probably the Coolant Temperature Sensor. Here's what happens. It's starts fine in the morning it starts fine after work...but when I go to the gym and try to start the car when I'm done it won't. I wait about 5 seconds, try again and it works. Same thing happens whenever I drive then try to restart within an hour or so. Now after I start the car after it does this I get an ECP light. I turn the car off and turn it back on...it goes away. Is that normal?
Anyone have the same problem?
Old Jun 30, 2007 | 04:32 PM
auditech79's Avatar
Default RE: Other Wierd Starting Problem Theard
If its cranking fine but not starting yes its the coolant temp sensor.
As for the ecp light check the fault codes, i bet you have a brake light switch fault.
Old Jun 30, 2007 | 04:37 PM
93Akkord's Avatar
yeah, forgot to say it cranks...brake light switch fault. what's that?
Old Jul 2, 2007 | 09:16 AM
jaynicols's Avatar
I have a 97 1.8T Quattro that I have the same issue with. When it warms up it just doesnt want to start but it doesnt happen all of the time. I had thought that maybe it was the ignition switch starting to go but Coolant Temp Sensor makes sense too. I will replace it and let you know if it works otherwise its a new ignition switch -- this is of course assuming that Audi's suffer from the same problem that VW's do with regards to the ignition switch. On that note does anyone know if there is a way to know if the ignition switch is working from the dash lights in an Audi? In a VW the battery light stays on when cranking to show that the ignition switch is working.
thanks
Old Jul 2, 2007 | 10:44 AM
david9999's Avatar
Pull the codes and post them back here.
Old Jul 2, 2007 | 01:45 PM
Lelix's Avatar
Could be a crank sensor
Old Jul 9, 2007 | 08:40 PM
jaynicols's Avatar
I replaced the Engine Coolant Thermostat (ECT) and things seem to be working well. Its only been a few days but the problem hasnt resurfaced.
I couldnt pull the codes since i dont have a VAG or other OBDII reader and there isnt anyone in the area that will read the codes for free like our US friends.
I will post again to confirm in about a week but so replacing the ECT is the solution
InfamousA4
Mar 11, 2009 09:39 AM
BraMas
Jan 30, 2009 11:51 PM
Brakisshuro
Sep 14, 2008 09:50 PM
superfly78209
Sep 13, 2007 06:41 PM
02A418T
Apr 6, 2007 07:50 AM
