ouch...
Old Aug 21, 2006 | 06:05 PM
chuckievi's Avatar
Default ouch...
Went to start my car before work today..... it turns over and thats about it. With the lack of independent Audi mechanics in Iowa, I may be forced to take it to the stealership.[:@]
Old Aug 21, 2006 | 06:44 PM
techbod's Avatar
Default RE: ouch...
check all the fuses ( does the fuel pump cycle when you turn the key??? ) does it have an immobiliser?? is there fuel in it
Old Aug 21, 2006 | 07:30 PM
chuckievi's Avatar
Default RE: ouch...
I wish I knew enough to answer your questions (other than the fuel). Basically I turn the key and it does the starter cycle but doesn't kick on. I can't really explain a whole lot more cus I just don't understand how it all works heh.
Old Aug 21, 2006 | 07:37 PM
techbod's Avatar
Default RE: ouch...
next step is there a spark at the plugs??
Old Aug 21, 2006 | 07:44 PM
chuckievi's Avatar
Default RE: ouch...
No idea, i'll have to check that when I get home. Do i Just pull em out and see if it sparks when I turn the ignition?
Old Aug 21, 2006 | 07:46 PM
techbod's Avatar
Default RE: ouch...
thats it mate your on the right track
Old Aug 21, 2006 | 07:49 PM
techbod's Avatar
Default RE: ouch...
it does the starter cycle don't confuse this by the starter motor turning what I mean is can you hear the fuel pump cycle without cranking the engine??
Old Aug 21, 2006 | 07:55 PM
chuckievi's Avatar
Default RE: ouch...
Ah you mean that whine sound when you put the key forward but don't actually engage the clutch and such?
Old Aug 21, 2006 | 07:59 PM
techbod's Avatar
Default RE: ouch...
turn ignition key till the dash lights come on but don't crank the engine then listen for the fuel pump to start for a second or so if nothing happens check all fuses
Old Aug 21, 2006 | 08:02 PM
chuckievi's Avatar
Default RE: ouch...
I didn't even think to check fuses when the initial problem happened, I'll check that out as well as the sparkplugs when I get home from work tonight.
