ouch...
Old Aug 21, 2006 | 08:04 PM
techbod's Avatar
Default RE: ouch...
its just basic mechanics mate and good luck
Old Aug 22, 2006 | 05:38 PM
chuckievi's Avatar
Default RE: ouch...
3 fuses a battery and 4 spark plugs later it runs again. On a side note the clicking sound that was happening when the car was cold went away too, kinda random.
thanks for all the help!
another side note, are iridium plugs really worth it? I was debating between them and the regular platinum ones that are 1/3 the price.
Old Aug 22, 2006 | 06:07 PM
onepoint8tee's Avatar
Default RE: ouch...
Depends on your engine. If you are 1.8t, plat and irridim is junk.. You want copper, especially if you are chipped or more. If you are 2.8 plats should be fine.
Old Aug 22, 2006 | 06:27 PM
chuckievi's Avatar
Default RE: ouch...
yeah I would forget to put that part in, I have a 99 1.8t
these are the plugs I got http://www.championsparkplugs.com/re...s.asp?pid=7346
Old Aug 22, 2006 | 06:51 PM
Default RE: ouch...
I wouldnt put a champion plug in my worst enemies butt. Get NGK BKR6E, needs replaced every 10k miles or so but are $1.89 a piece and perform better than plat.
Old Aug 22, 2006 | 06:57 PM
chuckievi's Avatar
Default RE: ouch...
thats the good info i need! thanks
Old Aug 22, 2006 | 06:59 PM
chuckievi's Avatar
Default RE: ouch...
So on the same topic, my car had 91k miles on it... other than the timing belt and the plugs I am about to replace what else should I be looking at doing to my car? I tried to search it but came up with nothing concrete, is there a good link of a spot to see what maintainace I need to get done?
Old Aug 22, 2006 | 07:10 PM
  #18
Default RE: ouch...
Nothing else really.. Check your valve cover gasket, youll need to replace your coolant when you do the timing belt so make sure you get the right stuff (audi g12 or pentosin g12) keep up on oil changes and keep it clean. Maybe fuel filter as preventative maint.
Old Aug 22, 2006 | 07:13 PM
  #19
chuckievi's Avatar
Default RE: ouch...
just read your post on the engine codes lean/rich thats good stuff. I can't wait for my break in 15 mins to go plug my VAG in and see if its my hoses or my MAF thats pissing me off!
you guys on this forum rule, saving me SO much money and keeping it out of the pockets of the evil stealerships.
Old Aug 23, 2006 | 12:01 AM
  #20
IDTrav's Avatar
Default RE: ouch...
geeezus onepoint i did not know that!!!! im still having cylinder misfiring after i put in some iridium plugs, hmmmm.
may i ask why they don't like iridium and prefer copper or just cuzzz
barney12
Mar 13, 2012 11:37 AM
Mac_17
Jul 31, 2007 07:46 PM
